I'm organising a HANDS ON Engine Performance Dyno Tuning Lesson at Unigroup Engineering.
It's a great opportunity, if not the only, to learn how to tune your own car from a well respected and knowledgeable workshop. Not only tuning but also understanding the mechanics and engineering behind modifications, and how everything fits together as a total package.Yavuz is the head tuner there and he's a UTS grad of mechanical engineering, many SAUers already go to him for tuning and some SAUers have also done the lessons and this is the kind of stuff they said...
I can not describe just how good this day was. The knowledge that yavus and his team where passing on was priceless, and can only come from years of experiance. The day was great we covered a range of topics. Not just spacific tuning topics but mechanical ones and how it effects tuning.
- Norm
This was a fantastic day. Thanks very much to Yavuz and the guys at unigroup for making the day flow and providing loads of information in a way that doesnt overwhelm.
The mixture of theory and hands on experience was excellent, allowing us to test the theory whilst it was still fresh in our minds.
I recommend this course to anyone who has an interest, i guarentee you will come away with alot!
Thankyou again!
- Amy
Had an Awesome time at unigroup on sunday, Yavuz IS the smartest tuner i have ever met. Best value for money, i learnt alot, we covered in detail every question the group had about tuning.
- Jeremy
I tried to cut/copy the info here but it got really messy so I'll put the link up with all the info here:
http://www.ao-ps.com/dynotuningsessionsgroup.php
Time: 10am – 4pm
Day: Sunday
Location: "Unigroup engineering" @ Unit 17/17a Amax Avenue Girraween, NSW, 2145
Cost: $500, lunch included, drinks included
Bookings: Email [email protected] or PM me to get your spot. 6 people max.
Date: July 15th, or
Date: July 22th, or
Date: July 29th, or
Date: August 5, or
Date: August 12.
How the date works is this; once 6 people have registered, we then select ONE date that suits everybody.
Edited by _Wing_
It was worth every cent, and more :D Yavuz covered some theory to explain, and then lots of time on the dyno with a couple of different cars demonstrating different points
Will the lesson include cold start tuning?
Also, what software(brand/brands) will be taught?
What car will lessons be held on?
Will lessons go into ethanol or even flex tuning?
Interested, will have to see if i can scrape together some coin.
at the course I was at they put 2 cars on the dyno, one had a powerfc, the other had a nistune.
there was really good coverage of the fundamentals, and then practical applications. eg how timing works, then how to test/set it for a given car, and then how cams/cam gears/vct might afftect it.
Yep it can include anything you want including cold start.
Unigroup has the software to tune most brands, like powerfc, nistune, motec, haltech, blackbox, link. Which one that's used on the day depends on the cars that get on, but one thing to keep in mind is that the tuning theory is universal so you can take it with you to any brand of ecu/software you've got.
The cars will depend on who wants to put their car on... maybe yours?
Yeah it can go into ethanol and flex fuel tuning too :)
  • 1 month later...
  • 2 months later...
  • 2 months later...
  • 3 weeks later...
  • 5 weeks later...
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
