Hi all, I have a question.
My base timing is set at 20 btdc by my tuner, and im sure it was 20 degrees before this, but I have just put on a ross balancer, and whenever i pull stuff apart I disconnect CAS so as to check everything over before re-connection and starting. Now I had a tune 1000 ish kms ago and I had Adjusted CAS previous to that to 20 degrees, he checked it and locked it into the ecu, and said it was good. However when I adjusted it, I hadnt tightened the bolts right up. 2 loose and 1 just nipped up a bit. All would be good but i may have moved it when disconnecting. So I tightened it up where it was. Check timing and its at 15 degrees, now the only variable is the balancer marks, My old one looked ok, I thought it might be rotated a little but seems fine. Now i trust the ross one is perfect.
So having retarded timing (i think) i figured no damage can happen, so i went for a drive, I only take it out every few weeks so I didnt notice any power difference. However I did a 4th gear pull right out and it had the odd cough feeling hesitation on full boost a couple of times and throughout the drive. It never has before.
So ill get to the point, is there a way to tell where it should be vs where ecu thinks it is?
Would the ross timing marks be perfect with stock balancer?
Just need some confirmation I dont want to set it at 20 and it be wrong. Im sure iv just bumped it around a tad but not sure if theres a way to make certain so I hope someone can clear this up.
Oh and I wasnt doing the 4th pull on the public road either. It was a local private air strip.
Thanks in advance
Thats what I have done, but im getting a different reading now with new balancer, im not sure if balancers are a bit different with readings or iv accidentally moved cas. Im thinking number 2
What ecu have u got! If ur base timing was 20 degrees btc then u had a tune, if u have a sftermarket ecu and the tuner has advanced the timing via the ecu to make more power then there is quite a chance that it wont be 20 degrees' all timing marks on any balancer should b as good if not better thsn standard.
Bedt bet would go to ur tuner and get a touch up tune just to b shure!
Im no expert though but thats what id do!
A tuner would rarely adjust the timing around idle unless there was a timing problem. There is no gain from advancing timing in these cells
Adjust your base timing back to 20 degrees if this was where it was set
I would go back no worries but its a 600+ km drive to do so.
If everyones confident the marks will be spot on I will just set it back to 20 degrees. Just sucks I didn't tighten it up properly!
I will contact tuner tomorrow and check but im dead sure it was 20 on balancer.
Just needed some confirmation thanks
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
