  • Replies 90
Back on topic - my personal fav: Early Oral Intervention! I'll take two to go please!
Acronym Definition
EOI Escuela Oficial de Idiomas (Spain, Official Languages School)
EOI End of Image
EOI End of Interrupt
EOI Escuela de Organización Industrial (Spain)
EOI Evidence of Identity (various nations)
EOI End of Input
EOI End Or Identify
EOI End of Instruction (type of exam)
EOI European Ombudsman Institute
EOI Equivalence of Input (telecommunications regulation)
EOI Earth Orbit Insertion
EOI Elf Only Inn (webcomic)
EOI End of Identity
EOI End Of Installation (US Navy)
EOI End of Item
EOI Electronic Order Interface
EOI Early Operational Interface
EOI Executive Office Installation
EOI Engineering Operating Instruction
EOI Effective Operating Income
EOI Early Oral Intervention
EOI Evidence of Insurability
EOI Extra Ordinary Income
EOI Explanation of Investment
EOI Emergency Operating Instruction(s)
EOI Export Oriented Industry
EOI Electronic Operator Interface
EOI End of Irradiation
EOI Effect of Interest
EOI Every Other Issue
EOI Evidence Of Insurance
EOI Expression Of Interest
EOI Electro-Optical Interface (Nortel)
EOI Engine of Innovation
EOI End of Innocence (music album)
EOI Export Oriented Industrialisation
EOI Embassy of India
EOI Exchange of Information
EOI Edge of Insanity
EOI Economic Opportunity Institute
https://www.sau.com.au/forums/topic/403435-eoi/page/3/#findComment-6417275
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
