  • 4 months later...
ok i need help. im doing the rotors on my r33, and cannot for the life of me figure out hoe to undo the caliper bolts on the rear. the frots are easy as you just turn the wheels out
take the rear wheel off. grab ya 17 and undo it from behind the caliper same as front bolted on from behind. and a belive brake calipers should be tensioned up to 89-100 ft pound or for all you dodge kents FT.
piece of piss
Edited by 32_Dave
from memory there is a bracket that holds the brake line or handbrake line. you need to take that off first. then you can access the bolt to take the caliper off.
  • 1 year later...
Thanks everyone who contributed to this thread, full rotors and pads job went without a hitch. Only thing I could add to the thread was the front rotors on a R34 GTR with the 324mm rotors will need a 10mm 1.25 pitched bolt instead of the 8mm bolt. And if you get caught like me without the 10mm bolt just take one of the bracket that the steering arm bumps into on full lock as its a 10mm 1.25 bolt.
cheers
Yep. Did this a couple of months ago. This thread helped me a Sh!t load.
Never done this before and now I've got 4 fresh rotors and pads all round !!!
First one was the slowest and the last was p!ss easy.
Savin' the Buck$ and bonding with my Baby. Love it!
SAU... I Love You!!! :cheers:
  • 2 years later...
Hi, about to do rotors and pads on my R33 which I haven't done before by myself. The old link for the pad changing is no longer valid :(
Is there anything crucial I need to know about changing them? Searched and got an R32 thread but none of the photos work
  • 10 months later...
  • 2 years later...
Old thread, but very useful to me today...
On 9/26/2006 at 5:48 PM, Flash89 said:
where is the adjuster?
the hand brake adjuster is at the bottom of the whole hand brake shoe assembly that sits inside the rear rotors.
With the rotor off you'll see the adjustment wheel - with the rotor on you need to rotate the hub (with the rubber plug removed from the rotor) so the hole is at the bottom and use a flat blade screwdriver to adjust the wheel the appropriate clicks - as above - rotate upwards until the hand brake shoes bind, then back off (rotate down) 5-6 clicks.
As above, when you have the rotors off, give the mechanism a good spray with Brake Cleaner.
cheers
Mike
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
