Hi all, going to upgrade my standard 33 s1 rb25 fuel system. looking at a walbro 255, tomei 740cc side feeds and a turbo smart regulator. from what i can gather those are all close to direct fit replacements. is it that easy? are there any major issues i will come across that im sure someone else would have already found? any help would be great
https://www.sau.com.au/forums/topic/403666-rb25-fuel-system-upgrade/
Do as was mentioned above, pump (hard wired for alternator voltage) and injectors.
You probably won't need 740's though, unless you are thinking this turbo isn't going to be the last/biggest one you get
In saying that Mitch i made the mistake of buying 550's and then had to buy 1000's later for E85, bigger isnt always a bad thing and the prices are similar, as long as they are decent injectors go nuts :)
By all means get the bigger injectors if planning to go e85 or get a bigger turbo down the track, as there is no difference in price really. But if intending to leave it at the highflow on 98 then 555's will do the job as well.
In retrospect i would have gone 740's as well because you get the power bug once you start!
yeah get good quality big cc injectors straight up 740s will cover you for alot of power...just saves headaches should you wish to upgrade later....
get big cc cheapo injectors now and you risk a crappy idle and bad fuel economy...
can we get a list of possible injectors for high power applications, so far i have deatchworks 1000cc but not sure bout idle and quality and fitment, power enterprise but have found they can have idle issues and be lazy? ID or xspurt 1000's but ill need to mess round with a top feed rail which is not encouraging, and then nismo's which are expensive,
just want to know what is the choice injector. and do it first time right...
Dude, it's a 25.... So many options!!! I went HKS rail and am happy az....
When it comes to advice, Guilt_Toy and Ash are as good as it gets, don't ignore it :)
you can xspurts or IDs in with the stock plenum on a 33 ,fuel rail is only 100$ regs arent too expensive either, fuel hose is cheap also and you will need a pressure gauge which is 20$..
I got.xspurts in 750cc in 40mm, which are shorter than IDs which are 48mm, so makes for an easier fit,, I think both will fit, I'm yet too see IDs with stock plenum but it could be done..
.Injector will cost you 6-700$ and they are amongst the best..Ask anyone and they will tell you they are great to tune, great at idle and great for economy too...
heres mine fitted up, I got them in without removing the plenum, tricky but possible
fuel rail
http://goodiesdirect...&product_id=405
Do it once, do it right... :thumbsup:
fuel rail
Thanks guys , just made my decision easy :thumbsup:
Just one last question, i rang EFI today and also horsepower solutions, 2 recommended on here about ethanol, got two different bits of advice
EFI said a 400lph walbro will be an absolute minimum for 300kw and need 800cc minimum injectors
Horsepower solutions says 2X 044 externals and was very sure about it, said ill use almost double the 98 i use when flat out
so the 2X 044's is extreme dont you think? and said ill make 320kw
now im thinking more that EFI know what there on about, but if a 400lph walbro is minimum what more can i do??
if the gtx3076 is to get upto 22psi without restriction, im thinking a walbro 400lph and Xspurt 1000's, should i expect 340kw's here?????
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
