So my car was missing under boost...I tried second hand yellowjackets and new plugs at 0.8... Still misses...
Then I do a turbo upgrade with pretty much everything new.. Both manifolds, injectors PFC fuel pump etc.... Still misses...
Today I went and bought new splitfires and put em in...miss got worse.... Now it's like really loud backfiring... Different to before.
Has anyone got any ideas to help me solve this problem.
https://www.sau.com.au/forums/topic/403712-misfire-from-hell/
Youve added a shit load of stuff to the equation now....should have sorted it before the upgrade, but still check CAS and make sure the blue plug on the ecu is in evenly, pressing in the ends and not over tightening the 10mm bolt, And I assume u changed the afm to Z32?
When you say backfire, on accel or decel?
Yeah it's missing on accel and sounds almost like a rev limiter with lots of little backfires..
Yeah it's a z32 afm and Toshi tuned it, we did what we could but we stopped when it was missing and I was going to go back and finish the tune once it's fixed.
Try gapping down your plugs to 0.6-0.65. I just did that and sorted my cutting problem at 0.8 Bar. Now good all the way to 1.4 Bar. I think my coils are loosing power so confirms that it is spark related.
Running that gap now with no probs at all, until the shop warms up to re-mount my coils (I run bosch coil set-up).
Dont think its actually the coils..For reference my splitfires had enough juice to run a gtx30 @20psi with wmi and 1.1mm gap
Sounds like an electrical gremlin....As said before check coil pack loom, ignitor if you have one, also make sure all earthing on the engine and batt terminals are clean and tight and again CAS
What plugs you running?
So if you get mad backfiring an high in the rev range it could be leaning out coz of the pump?
Definitely, mine did the same thing today on the dyno, changed coils, gapped plugs, no change. Ended up being one of the pos Walbro 342's not pumping properly. It seems they need to be fully submerged to operate at maximum flow, unless its just faulty... I was hoping the deatschwerks didn't have the same design flaw as this fault was occurring at 1/3 tank.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
