Yes I get the feeling that Pilot Preceda 2s were not their high end tyre and more a slightly upmarket all rounder . Having said that they are pretty good all rounders and real good in the wet . If I go looking for 255 40s I'll probably start with Pilot Sport 2s .
A .
  • Replies 58
It already has pinapples in it , the full Sk Whiteline Bilstein kit not just the struts and springs .
Just thinking hard ATM about the full GTR rear end set meaning dampers uprights etc etc to the diff center . I know a few people here have done this and probably the only new bits would be the Bilsteins with the "fork" mounts .
Can someone tell me roughly what an R33 GTRs rear end bits cost second hand - meaning diff stubs shafts uprights and hubs ? Probably need lower control arms too to make it easy . The other question is do the RWD LCAs have aftermarket bushes in Whitelines kit and if so can they be reused ?
I'm going to look in the DIY/Tutorial section to see if anyones done this conversion to a RWD R33 and posted pics , cheers A .
Sorry one more , Gary tells me some R32GTSTs had clutch LSDs in them . Do their stub shafts suit GTS25Ts half shafts or do they have 3x2 bolt flanges like Silvias ?
Disco you are going the hard way about it. Alignment first. Replace 5 yr old tyres second.
I figure its going to cost me tyres and a clutch plate LSD .
Andrew I think for the costs involved may as well have a factory CLSD and doing that means hanging the 30 spline axles and matching 6 bolt shafts off it .
Really the only down side is replacing dampers that aren't worn out . It would need a wheel alignment anyway so thats just part of it .
A .
you really don't listen do you? :yes:
Spend $60 on a wheel alignment, try to get the guy to run minimal negative camber and replace your dinosaur tyres. I kid you not, I made more power than you and held it flat on the ground with cheap Kumho KU31 255/40/17 tyres
In Sydney, I bring it to BT Motorsports in Fairfield, they're also a Bridgestone Select dealer (what ever that means). They will let you go into their workshop and show you what they're doing on your car. You can also tell them what you want dialed in.
Good job + print out and they will point out any problems/issues unlike most other places. I think they have a liking for Nissans too, last time I was there, they had a nice looking GT-R in the shop with a blown gearbox, I told them to hop onto SAU as there was someone selling a sequential box.
Can't remember the dude I spoke to, but the car drove heaps better afterwards too.
I understand the one wheel concept, Just wondering if it will have trouble putting the power to the ground. seeing as its over a 200KW jump in power, On the same diff ;/
Ever seen a VN Commodore single wheel up the road with only 120rwkW? Well, it'll be twice as bad as that.
mabey a little OT, But would a car have much dramas, Traction wise mainly with putting 300+ kw through stock open diff, Or what ever the NA has?
I had 311rwkw with a stock gtst diff (single pegger at that power level) for about a week while my diff was in transit...
doing 100+ you would crabwalk as soon as you floored it.
I run 235/40/18 bridgestone potenzas inflated to 40psi on +38 (shit)offset RAYS Volk lightweight wheels, stock diff I think, and a measly 200rwkw. The car came with Cusco adjustable suspension which is too hard for my liking, and is lowered to ok height.
I spin first easy and second spins a fair bit too when giving it some stick driving straight, it usually side steps, I never LAUNCH. I would really like to avoid this spinning and sidestepping, I think I'm running too much tyre pressure, too skinny tyres with bad offset and a hard suspension, maybe get some pineapples, would like to soften er up...hmmm
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
