  • 8 months later...
Hey all,
Just wanted to ask a quick one about fuel filters. What are you guys using these days? I've read a number of older posts about using the standard Ryco filters, some good some bad. I'm also aware of the situation with needing to replace fuel filters regularly just after switching to E85 until the system is clean. So right now I'm considering three paths.
1. I stick with the Ryco paper filter and just replace it regularly.
2. I stick with the Ryco paper filter for now, then after my first tank of E85, switch to a billet filter (Aeroflow, Speedflow, Proflow, or similar?)
3. I switch to a billet filter now, before getting the E85 tune.
At the moment I'm leaning towards option 3 for a couple of reasons. Firstly I have the standard feed line to my Ryco filter, then a -6 fuel line to my HKS rail. It works, but considering the Ryco filter has 5/16 push on barbs, it doesn't quite fit as nicely as I would like. With the billet filter I could use a -6 AN fitting on one side, and a -6 AN to 5/16 tail barb on the other side. Second, if I need to replace filters regularly, would a washable element not be a cost effective solution?
  • Like 1
I use twin -6 an stainless mesh filters, Proflow ones, they cost around $100 each though plus fittings. No issues in 3 years daily driving on United mainly, and they have never been cleaned.
Do you know what micron filter element you've got, Scott?
Another one, where are people mounting their GM flex-fuel sensors? I've got the flow through type and I thought I could mount it between my regulator and return line in the engine bay, but I can't see it happening. This thing is quite hard to mount with the factory hard lines :glare:
In the boot. Tee off the return line just before it drops back into the tank. Hidden sensor FTW!
Yeh? I did think of putting it there. Could maybe work something out... All seems a bit tight though, I can hardly see my return line let alone find a place to put two tees into it :/
Edited by Hanaldo
BRB, taking a photo for you :P
I think it's 100 micron mesh.
Don't you want the sensor as close to the rail as possible?
I can't see how it makes any difference. Either way, once the fuel is mixed, it's the same. Just dontn belt it until you see the reading settle.
Ah, you got the little small thing.
Yeh so they say. Its fkn massive! Ideally I would mount it close to the rail, but I can't see it fitting anywhere unless I remote mount the sensor and run like 2 meters of hose to it :/
Under the car?
Just curious why I've seen a few setups with the flex sensor mounted in the boot? Another car I've seen setup by UNIGROUP has the flex sensor in the boot too?
What are the benefits? Is it just a convenience thing or heat stress thing?
It's one less thing in an already full engine bay. No other reason.
How many free 0-5V inputs do you need on your ecu? The zeitronix Eca kit outputs fuel temp and ethanol % doesn't it?
1 I'm pretty sure. And yes fuel temp too. You can set up fuel temp correction too
Under the car?
Yeh this is what I was thinking of. It would be so much easier if I could cut the standard hard line, but I don't want to lose the flared end.
I think the easiest thing would just be to run a longer length of hose to the sensor. Just seems such a messy way of doing it :/
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
