Hay Kate!
Welcome, hope you enjoy your stay. Lots and lots of info in here. If in doubt use the search function and you should find some info. Can recommend people to work on your car too should something need attention.
Dont worry about the trolls. Plenty here. Provide the Lolz mostly.
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6446185
Haha no problem, thanks! Yes that would have been I remember I saw your post in spot the stagea.. :) looking at going to the cruise on 22nd, should be good.
You will find a lot of usefull threads on here and the meets are great too....
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6446721
had a quick look at your profile, definately need to put some pics up (of your car please) and also yes i'm still i believe the youngest active member on here at 22 yay!! glad to see i'm not the only young person who likes these cars, my mates all give me so much s*** for driving a wagon, even though i need the space for work, and for my son.
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6447212
Oooh, I could be younger :-)
I'm 23 in November
Also, welcome to the stagea girl
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6447524
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
