1 YEAR REGO JUST PAYED! 18/07 2013
hey guys im in sydney right now just wondering if anyone is after a r33 GTST 1995 4 speed automatic
after market t-3 turbo and greddy intake manifold fitted. plus internal wastegate for turbo set up pretty stealth.
hks turbo timer rating above 500hp after tuned and boosted (still running on standard boost 8psi ).
very nice car for street purpose use.
colour:metallic grey 17inch r34 GTT rims painted black with aftermarket center caps+ different colour wheel nuts on each rim.
dont miss your chance of buying guys! great car for sale sad to see it go. (rated price is 12k for a honest buyer price is always negotiable i want someone who truly loves this car)
gimme a buzz or text msg anytime 0410231622 lee hope to see you soon.(fairfield area however i will be moving to st clair area sooner or later. FYI)
Edited by lee8246
https://www.sau.com.au/forums/topic/404954-skyline-r33-gtst-for-sale-urgent/
Silver bootlid, multi coloured wheel nuts, green lookin headlights, sounds tasteful, put a std turbo on and halve your price and you might get some serious offers...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
