Hi Guys,
Ok I've got some used spare parts and I'm prepared to let them go pretty cheap to free up some space in the garage.
2010 OEM 20 inch wheels with 50% used Dunlop's - $3,000 (There are a few scratches on two of the wheels. Easily fixed if repainted though)
Full exhaust - $2,500
80 mm straight through dump pipes
100 mm twin resonated midpipe
90 mm Rear section Inc two mufflers
This is the full exhaust that I ran on the car at Bathurst last November. Its not going to save you as much weight as a titanium system would but its still much lighter than stock and It's super quiet for daily driving but when you get the power down it comes on song very nicely. It's good for up to 800 hp. I'm selling it because I need something lighter. here is a clip of how it sounds
2x OEM Front seats - $5,000 for both
2x OEM Doors white - $5,000 for both
1xOEM Bonnet white - $3,000
2xOEM Turbo Chargers - $4,000 for both
Give me a call or email if your interested.
0418 290 615
[email protected]
Miles..
  • Replies 227
Dodson built transmission for sale. CLICK HERE!
I have a fully built Dodson GR6 transmission
Parts list below, pretty much the full Dodson Catalog.
our race only car is going to a lightweight specially adapted rear wheel drive transmission which is a change in direction after our new transmission was just finished being built in December. The transmission has never been used (other than the standard Run in and check by the Dodson authorised Technician test car). Also has all the new Dodson tranny and diff oils. ATS Carbon Rear diff.
All the parts are brand new. Read: Brand new promax clutch, Brand new 1-6 straight cut greatest. and all the parts listed below.
We also have a a billet transmission selector fork installed (this is the fork that failed in my transmission originally)
I don't need a transmission swap but will consider if it makes the sale.
The full build cost and supply of a second hand transmission would fetch AU$55,000
Will sell for $49,000.
Steve Thatcher From JustJap in Sydney (the Dodson authorised australian technicians) will happily answer any questions/verify the work and the install. his email is:
Steve Thatcher [email protected]
R35 CPM PRO MAX COMPLETE CLUTCH 1000 FT/LBS+
R35 MC1 2MM MECHANICAL CIRCLIP 1 2MM
R35 MC2 MECHANICAL CIRCLIP 2
R35 GL GEAR LOCK FOR FWD TRANFER GEAR
R35 ORK O RING KIT
R35 OPK OIL PUMP UPGRADE AND REPAIR KIT
R35 DCS HIGH TEMP DIFF SIDE COVER SEAL
R35 TP BILLET ALLOY TRANSMISSION PAN/SUMP includes R35MK
R35 TF TRANSMISSION FILTER REUSEABLE
R35 TFP TRANSMISSION FLUID + 30 DEG AMBIENT
R35 DO1 HEAVY DUTY DIFFERENTIAL OIL
R35 ETS ENGINE TEMP SWITCH 68 DEG C
R35 RSS HEAVY DUTY CLUTCH RETURN SPRING SEAL
R35 OPP OIL PUMP END PLATE AND GASKET
R35 6SGS SC 6 SPEED GEAR SET STRAIGHT CUT
R35 FWDCH FWD UPGRADED CLUTCH HOUSING
R35 FWDCP FWD UPGRADED CLUTCH
R35 FWDP FRONT WHEEL DRIVE PINION
R35 FOS FWD OUTPUT SHAFT
hi all have a set of RS-D up for sell
20 x 9.5 +40 x2
20 x 10.5 +12 x 2
colour is black with chrome lip
condition is (brand new condition) no marks or scratches on the lip or spokes itself
remarks: only lock nut mark inside the lock nut hole.
asking $4900
1331547821[/url]' post='6271583']
R35 ORK O RING KIT
Price drop
$45,000 without tranny swap
$37,000 with a good condition tranny swap
Hi everyone,
I have for sale a brand new OEM Nissan R35 GTR car cover with carrycase. Purchased from USA but was never used.
Asking $300, however open to offers. Below is the ebay link;
My link
Item is located in Norwest NSW 2155 (just off the M7).
If your interested please contact me on 0411 415 644.
Rohin
Edited by Admin.
If you wish to advertise the parts you are selling on this forum, you are required to become a business trader.
See the following thread for further information:
http://www.skylinesaustralia.com/forums/topic/294953-are-you-a-business-want-to-advertise-on-sau-click-here/
ok standard width top racing front bumper and carbon fenders going out the door $3500 for the lot excl shipping. otherwise they are off to Dubai by next week!
thats AU7000 of carbon parts adn AU2000 shipping from hong kong - its a steal
Hi mate,
Is this still available? I am in Hong Kong and can pick up from Top Racing.
Thanks
Rob
Hi Guys, Sold the R35 and have left
a brand new Greddy R35 motor shrink wrapped that I kept as a spare, $14,000
a set of brand new set of Run flat R35 tyres from USA in plastic $2000
Im in Northmead near Parramatta Sydney NSW.
Dom 0414 62 62 43
And the new race car has 306.1 kwatts ATW weighs 100+kgs less than an R35 and does eastern creek in about 2 mins in the dry and 3 mins in the wet using 3 sets of rear tyres per lap. But boy is it fun.
So what is it?
Dom 0414 62 62 43
So what is it?
Wow you must change tyres quickly.
  • 3 weeks later...
2 x 2008 model Black Edition GTR seats (grey with red inserts) in as new condition
1 x 2008 set of brakes (several sets of second hand discs AP/stock mainly stuffed) - all working fine 12,000km from new
1 x 2012 set of brakes as new (travelled under 100km)
Make me an offer....
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
