gloof Posted May 9, 2004 Share Posted May 9, 2004 is a custom 600x300x90 cooler 2 big for a stock r33 turbo? Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/ Share on other sites More sharing options...
RBVS Posted May 9, 2004 Share Posted May 9, 2004 is a custom 600x300x90 cooler 2 big for a stock r33 turbo? some would say yes some no, id say no. In rev 210 post of doing a 13 from a stockish r33 he feels the stock cooler to be more effective because you lose less boost though it than a larger cooler. I think a cooler intake temp may be more beneficial as when you mod more you keep getting gains from it. Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-831941 Share on other sites More sharing options...
RBVS Posted May 9, 2004 Share Posted May 9, 2004 as for size most up grades are 600, 300, 75 i dont think 90mm is over kill Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-831942 Share on other sites More sharing options...
sweetr33 Posted May 9, 2004 Share Posted May 9, 2004 in all honesty i think most items will be better than the stock unit, unless its like some massive drag core or soemthing Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-831990 Share on other sites More sharing options...
nismo_au Posted May 9, 2004 Share Posted May 9, 2004 What kind of power are you looking at achieving would be nice to know. If your just going to be dealing with the stock turbo im guessing close to 200rwkw? If this is the case then I would suggest IMHO going for something a little smaller (600 x 300 x 65 to 600 x 300 x 75 in size) as the larger core in question won’t really provide any extra benefits when dealing with the stock turbo, in fact it will have a greater adverse affect on overall engine response. The diameter and length of the intercooler piping will also play a major role in determining how much it will affect engine response. If you only plan on keeping the stock turbo for a little while and will be looking to upgrade to a bigger item in the future then it may be worthwhile going for a 600 x 300 x 90 sized unit (depends in the end what power goal you are looking to achieve and any future upgrade you have in mind). Otherwise, if the stock turbo is all your going to have then I would go for something a bit smaller, as i have suggested above. Just my 2 cents, hope it helps… Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-832094 Share on other sites More sharing options...
nismo_au Posted May 9, 2004 Share Posted May 9, 2004 Originally Posted by RBVSIn rev 210 post of doing a 13 from a stockish r33 he feels the stock cooler to be more effective because you lose less boost though it than a larger cooler. Hmmm, im not sure if that is why he kept the stock cooler for so long. I was under the impression that the stock intercooler would actually have a greater drop in pressure than a well designed larger item (but I guess the extent of this would differ at different boost levels). From memory he was boosting somewhere around 10-12psi, a sensible level for the stock intercooler. I thought it was Rev210’s intention to keep the stock intercooler to retain the greater engine response from a smaller cooler (shorter length of intercooler piping and smaller volume of core). Could be wrong though… Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-832141 Share on other sites More sharing options...
gloof Posted May 9, 2004 Author Share Posted May 9, 2004 i'm aiming for 200rwkw no more. It's because my mechanic has a core that size and i'm getting it all custom made and then tuned for $1320. It's a great deal but i don't want to lose responsiveness Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-832578 Share on other sites More sharing options...
MADGT4 Posted May 9, 2004 Share Posted May 9, 2004 My Mate has a 600x300x100 on his 33 It has Stock Turbo, Cat Back and Boost Contoller and it makes 200rwkw @ 14psi...... He does have some idling problems tho but as soon as the car is going...... ITS A GUN! Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-832723 Share on other sites More sharing options...
gobiz Posted May 9, 2004 Share Posted May 9, 2004 Ive got a HKS GT 600x300x100mm and I havent lost any responsiveness with my stockie turbo, boost still starts to come on at around 2500k if I go a bit heavy of the right foot. Going GTR soon though;) Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-832728 Share on other sites More sharing options...
gloof Posted May 11, 2004 Author Share Posted May 11, 2004 how about if i he cuts the core down to 600x250x90 Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-835269 Share on other sites More sharing options...
gloof Posted May 11, 2004 Author Share Posted May 11, 2004 if he cuts the core to 600x250x90 Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-835293 Share on other sites More sharing options...
nismo_au Posted May 11, 2004 Share Posted May 11, 2004 Gloof, I had a similar question to what you were asking before I decided on what sized intercooler I was going to buy. Here is the link: http://www.skylinesaustralia.com/forums/sh...ead.php?t=36533 The link Meshmesh pointed me to and SydneyKids response were both very helpful. Hope they help you too. Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-835624 Share on other sites More sharing options...
WazR32GTSt Posted May 12, 2004 Share Posted May 12, 2004 i would htink at the end of the day you are removing the stock intercooler and replacing with one that flows better and has a smaller pressure drop. the amount of 'lag' that people generally refer to that comes with an aftermarket intercooler and piping is something so small that i would render it irrelevant. get the cooler mate... Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-837361 Share on other sites More sharing options...
Jaws Posted May 12, 2004 Share Posted May 12, 2004 While on the topic i also have a similar question. This is my set up. Rb30det. *power fc. *gt3040 (600hp) *standard Rb25 inlet manifold. *high mount exhaust manifold. * water injection (maybe) Looking for 300rwkw.(1200kg car) Will :600x300x76 with 3 inch inlet and outlets. flows 381 cfu. be good enough.? Or should I go: 600x300x100 with 3 inch inlet and outlets.? Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-838756 Share on other sites More sharing options...
gloof Posted May 21, 2004 Author Share Posted May 21, 2004 then has anyone fitted a hybrid cooler using the stock inlet and outlet? Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-851049 Share on other sites More sharing options...
Merli Posted May 21, 2004 Share Posted May 21, 2004 Weaksauce, 600x300x115 or bust!!! Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-851062 Share on other sites More sharing options...
BU5TER Posted May 21, 2004 Share Posted May 21, 2004 Weaksauce,600x300x115 or bust!!! :werd: Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-851236 Share on other sites More sharing options...
Col-GTSX Posted May 21, 2004 Share Posted May 21, 2004 My first FMIC was a 110mm thick unit to make up for lack of height.... It had major heating problems for the radiator.... My temp gadge would always be up around the high area.... New skyline got a 645x350x75 custom made and this worked a charm... Although it covered the entire radiator it was no where near as thick.... Current skyline..... Dont even have FMIC on road.... Have interchangabe piping for dyno.... But it runs too hot as well in summer.... its a 82mm thick.... I wish I wish i didnt kill that fish (had my last one stolen) Point of my story... 3 skylines... 2 the same pretty much, and very different in performance... Link to comment https://www.sau.com.au/forums/topic/40530-is-this-2-big-600x300x90/#findComment-851678 Share on other sites More sharing options...
