is a custom 600x300x90 cooler 2 big for a stock r33 turbo?
some would say yes some no, id say no. In rev 210 post of doing a 13 from a stockish r33 he feels the stock cooler to be more effective because you lose less boost though it than a larger cooler. I think a cooler intake temp may be more beneficial as when you mod more you keep getting gains from it.
What kind of power are you looking at achieving would be nice to know. If your just going to be dealing with the stock turbo im guessing close to 200rwkw? If this is the case then I would suggest IMHO going for something a little smaller (600 x 300 x 65 to 600 x 300 x 75 in size) as the larger core in question won’t really provide any extra benefits when dealing with the stock turbo, in fact it will have a greater adverse affect on overall engine response. The diameter and length of the intercooler piping will also play a major role in determining how much it will affect engine response.
If you only plan on keeping the stock turbo for a little while and will be looking to upgrade to a bigger item in the future then it may be worthwhile going for a 600 x 300 x 90 sized unit (depends in the end what power goal you are looking to achieve and any future upgrade you have in mind). Otherwise, if the stock turbo is all your going to have then I would go for something a bit smaller, as i have suggested above.
Just my 2 cents, hope it helps…
Hmmm, im not sure if that is why he kept the stock cooler for so long. I was under the impression that the stock intercooler would actually have a greater drop in pressure than a well designed larger item (but I guess the extent of this would differ at different boost levels). From memory he was boosting somewhere around 10-12psi, a sensible level for the stock intercooler. I thought it was Rev210’s intention to keep the stock intercooler to retain the greater engine response from a smaller cooler (shorter length of intercooler piping and smaller volume of core). Could be wrong though…
Gloof, I had a similar question to what you were asking before I decided on what sized intercooler I was going to buy. Here is the link: http://www.skylinesaustralia.com/forums/sh...ead.php?t=36533
The link Meshmesh pointed me to and SydneyKids response were both very helpful.
Hope they help you too.
i would htink at the end of the day you are removing the stock intercooler and replacing with one that flows better and has a smaller pressure drop. the amount of 'lag' that people generally refer to that comes with an aftermarket intercooler and piping is something so small that i would render it irrelevant.
get the cooler mate...
While on the topic i also have a similar question.
This is my set up.
Rb30det.
*power fc.
*gt3040 (600hp)
*standard Rb25 inlet manifold.
*high mount exhaust manifold.
* water injection (maybe)
Looking for 300rwkw.(1200kg car)
Will :600x300x76 with 3 inch inlet and outlets. flows 381 cfu. be good enough.?
Or should I go: 600x300x100 with 3 inch inlet and outlets.?
My first FMIC was a 110mm thick unit to make up for lack of height.... It had major heating problems for the radiator.... My temp gadge would always be up around the high area....
New skyline got a 645x350x75 custom made and this worked a charm... Although it covered the entire radiator it was no where near as thick....
Current skyline..... Dont even have FMIC on road.... Have interchangabe piping for dyno.... But it runs too hot as well in summer.... its a 82mm thick....
I wish I wish i didnt kill that fish (had my last one stolen)
Point of my story... 3 skylines... 2 the same pretty much, and very different in performance...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
