  • 3 weeks later...
  • 1 month later...
  • 3 years later...
New thread with pics. (mods please delete old thread
Parting out a complete 33 gtst with nice mods. Some stuff has been sold, listed below is whats available
bigger items are pickup only, will post smaller items at buyers cost. I am located in Ipswich qld and can be reached via pm or ph. 0413863207
I will be attending superlap in sydney next week so some items depending on size can be delivered personally at the event.
Some parts ore not pictured. a brief list below
RB 25 engine, only, no ancillarys. good engine maintained byy ERD....800 dollars
RB starter motor....100 dollars
Power steering pump ....100 dollars
Alternator.....75 dollars
Air con compressor.....100 dollars
HKS Hyper D coilovers in excellent condition complete with external adjusters for the rear and c spanner and adjustment tool.....650 dollars
SUB Zero plenum with ford throttle body, tps, Lobster tail piping with tial 48 mil atmo gate, These pleums have been used to make big power and retain the factory runners to improve response and mid range.....750 dollars or will seperate
Very clever catch can with speedflo fittings and braided lines. There is an atmo tube running up underneath so as to remaiin stealth and defect free.....125 dollars
speedo cluster sold subject to payment
complete hot side consisting of near new bmc 4 inch filter to garret 35R turbo with .82 rear housing, Sub zero low mount manifold, sub zero 60 mil wastegate plumbed back, custom dump, turbo to intercooler custom piping, all oil and water lines (mostly braid, Full 3 inch exhaust with near new cannon and steel cat.
Absolutely complete hotside upgrade with all quality gear ready to just bolt straght on to a 33 gtst....BARGAIN!!!.....2000 dollars
As new cooling pro 100 mil intercooler suit gtr or gtst, perfect condition.....250 dollars
Unmolested front reo from series 1 33 gtst, clear those defects....200 dollars
Genuine nissan m spec sideskirts, passenger side needs a small plastic repair but otherwise excellent.....125 dollars
Factory pods in mint.....100 dollars
Nismo 550 sidefeed injectors in 25 fuel rail, no issues at all....500 dollars
dash surround, I have 2 in good condition.....50 dollars each
Clear rear garnish (2 again) .....40 d0llars each
rb25 coils and coil loom no cracks or faults.....100 dollars
Series 1 antenna.....50 dollars
the little tray thingy that goes under the climate control, again I have 2 of these....20 dollars each.
drivers side electric window reg.....75 dollars
cas......75 dollars
Indicator, wiper stalk....50 dollars
pair of series 1 headlights in good nuck, just need a polish, (i can do it)....250 dollars
Genuine greddy boost guage in greddy pillar pod.....150 dollars
as new handbrake and gear lever boot red stitching inc gear surround plaastic with lighter.....40 dollars
33 climate control in good working condition.....50 dollars
drivers side window motor, (I have 2) 100 dollars each
As brand new mongoose alarm with all sensors and switches plus the 2 remotes. Only been in car a very very short time.....200 dollars
full lock and key set for 33 gtst inc both door barrels, ignition, and boot barrel....100 dollars
hi is the full lock and key set for 33 gtst inc both door barrels, ignition, and boot barrel still available??? Edited by yaya
Hi,
I'll buy the as new handbrake and gear lever boot red stitching inc gear surround plaastic with lighter.....40 dollars if its still available.
Let me know shipping cost to Melbourne. Thanks.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
