  • Replies 96
Posted Images
did you use software to blur the backgrounds into perfect bokeh?
definitely software. you can see the edge of the selection in the first pic (looks like a halo around the cars that is slightly brighter than the rest of the background)
Edited by Jay019
Yes mate. Cars didnt pop as much as I wanted them to so blurred the background a bit more.
Still learning, so thanks for picking that up. Thought i removed the halo's but will try focus on this more for next time.
How about you guys? Do you use software to finalise your pics as well?
really impressive dan! you've got skills! Love the first shot. not one thing I dislike or would change.
went to wtac. was rad.
click HERE for wallpaper
Love this one, perfection.
Again so sharp and love the flames.
i havent used it to fake bokeh, but one of the things that gives it away is the unfocused ground right under the in focus cars. wouldnt happen with an in camera shot. maybe try to fade out the selection on the plane where the focus would naturally fall. also, did you feather the edge of the selection or do anything to 'refine' the edges? not a bad attempt, much better than some I have seen thats for sure. but yeah, still has a few of those tell tale signs that are easy to spot. the bottom two arent too bad, but the top one its a bit easier to spot.
awesome lighting and perfect white balance tho (something i worry too much about, lol) and composition is spot on.
Edited by Jay019
Thanks for the tips mate.
I've learnt through reading photo tutorials and wanted to give that form of editing a go, still trying to perfect so really appreciate the advice, anything to make my photos better.
I didnt blur the actual ground, only from the cars front lips up. I did drop a soft light gradient from the bottom of the pic up to the front lips though as the ground looked a little too over exposed for my liking. Maybe this is where it went overboard?
ps: I love the night shots in your last post, I'm a real fan of the slow shutter stuff.
used light room and ps above to remove some flag poles
i use it a bit for graff shots. like joining up multiple pics of long walls and removing trees and stuff. most times when doing the joinups i just use the automated tools, but it doesnt always go to plan...
i also use it to fix stuff like flash glare...
and to fix pieces attacked by the comsec wankers...
That would have taken looooong time to do i'd imagine
ive been a bit of a ghost lately, been heaps busy and stuff. will try to post up some more over next couple days.
definately some quality popping up which i like to see!
p.s.
Wil, that chick is fcking hot!
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
