Hi guys, just recently my interior lights wont work when I open the door. It's not fuse related (well I don't think) and not bulb related. Nor is it light fitting related (I swapped rear to front) the rear works great but the front only works if you turn it to the "on" position. The door switches are working and the open door symbol on the dash works when the key is turned and the "key in ignition" bell works when you open the door. I get 12.45vdc at the door and I know it's only switching the ground but I can't buy this one out? Is there a relay or something else controlling interior lights?? Any help on this would be greatly appreciated.
https://www.sau.com.au/forums/topic/406279-interior-light-problems/
Yes there's a relay and a timer that keeps the lights on after you close the door until you start the engine. Where it is I can't remember but if you find it I may have a spare as I have a binfull of relays I got from an S1 that I wrecked for parts!
btw this is (hopefully) the key to the fusebox behid the coin drawer:
Thanks for that i had thought of that. Ill have to try to find it. That is the S1 fuse layout, i have a S2. But thanks for the thought. I already found the S2 one and know its not a fuse. Just need to find that relay..... if anyone knows that would be a great help, and if it is the problem i would like to grab that one from your "bin of stagea spares" lol what else is in that bin out of interest?
Not much TBH - sold all the obvious stuff - just have some odd relays and sensors left.
the dash cluster (speedo etc) has the BCM inside it. that runs the the lights. there is also a smartentrance module next the the fusebox that also drives the lights. this is more for the S1 though.
BCM? I hav the cluster out nothing seams obvious or easily replaced for that matter. What's the control box look like? Black and too the left of fuse box by any chance?
I've got cluster out and appart. Nothing really seams to look like a control unit. Behind the cluster is the PE cell for auto head lights is the timer in there? I'm thinking not. I pulled out the black box next to the fuses , it's the bell for making annoying noises, is it in there? Other wise I'm in struggle town with our a map... :(
Ok. So on top of the fuse box is a white box which wen I pulled pulled out was able to continuity test out the wire from the door switch to its connector. It's a sealed unit with some holes on top (im thinking it has buzzer or something in it.
Ok I hav the white TCU (timing control unit) out of the car. I'm pretty sure it's what I need (looked up the part number was all in jap so google translated it) I'll try to put up a pic ( haven't done it before :)
it will say smart entrance on the side of it. they are common with R33 as well. that does the majority of the body stuff. the locks and lights also loop through the cluster. SE module is a possible culprit.
Im not sure mine is the same? are you talking about S1 or S2? Mines S2 and i think it could be different. All the things you describe dont seam to be behind my dash bits? I found the TCU and looked it up on google, got a bunch of stuff in jap and russian but i translated it and it seams to be the part im looking for? It does the key in ignition and reversing tones, it also controls the door locks. Im kinda sure it does the interior light timing and a few other things, but not 100% My fuse box also has some relays on it but when i trace my door switch wires i can only get them back to the TCU....
Can't for the life of me remember which colour the box was, but it had a few wires going in (more than I expected) and covered all the beeping functions including reverse which I was trying to kill. It also seemed to control the remote start for my car.
there may be a few different boxes depending on series and options
Yes mines the same. It's white and has a small metal bracket on the side to bolt it in place above the fuse box. It does all the tones and locks etc and I'm pretty sure it does lights. Does any one know where I can get a new one from? Remote start sounds cool if I can get one with this :)
Ok so decided to give up on the control box. Too expensive and hard to find to care. So what I did (which was my original plan) was to hook up under dash and rear seat foot well lighting and do away with the control box and timer etc. If you have this problem and need it fixed the control box replacement will fix it. But in the process of doing my foot well lights I got rid of the annoying beeping, HOWEVER! It also gets rid of the "head lights on" tone and this could result in some flat battery's! Just remember to turn your lights off :) Ill put pics up of my lights tomorrow :)
  • Like 1
  • Thanks 1
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
