I tend to leave from Northcote at 5:45am, though I don't stop on the way. Note I don't go through Cranbourne either - I head towards Pakenham on the Freeway and cut down Koo Wee Rup Road.
Went down to Chasers to have the engine checked out, don't know if the other garage's instrument read low last time but compression was again even but up at around 160 per cylinder, leak down test was also very good. Looks like I can continue to target my money at the rear suspension and possibly Paul Ruzic EM Pro to provide engine monitoring to keep it so - currently just have standard dash.
  • Replies 49
Posted Images
good news on the comp test, just keep it cool and fill it with fresh oil frequently and bobs your uncle!
i'd love to throw some money at the rear end in my car, it's a constant struggle trying to keep it straight.
have fun at the island!
putting 300kw through my stock rear end was a nightmare at Sandown I just couldnt get on it anywhere but the straights, even then it was point and shoot but dont pull the trigger to hard
...wasnt too bad at PI though, just drove like a normal car but faster,only on the tight tight handers it wanted to step out :D
1.5Way KAAZ or NISMO diff is a must. it's $1500 worth of kit, but money well spent.
This is what Birds was telling me.
How much of a difference did you notice? Just traction out of corners or....?
Yeah diff and brakes is the last big spend I have really..It will have to wait though so in the meantime I will just cruise around and learn the road..
And swaybars..mind of I ask what sizes you run John or is it secret squirrel business..
Adjustable Whiteline Front, there is only one size 24mm.
Fixed Whitline Rear, 20mm.
The diff changes the way the car behaves, not only under power but off power into corners. It's less sloppy and more direct, the change on the road is equally as good. Rob in the black 33 just changed from the stock diff to a KAAZ 1.5 way recently.
GTR is different. The GTR rear subframe is different so is the front (obvious reasons there, front diff)
27mm for the front of the ECR33 is fixed mate. That would be terrible, unless you like massive understeer all the time.
My entry was confirmed by email yesterday too, as scrutiny opens at 7:30 I guess we would need to be there around that time, especially with up to 140 entrants.
I will be meeting other drivers at McDonalds Cranbourne at 6am if you want to get a quick bite and head down with us.
cool, i'll try to make it by then however i'll probably be running late and miss you guys.
What a gorgeous day, looking forward to tomorrow. Where are you planning to park up, if early, close to cafe or at far end of garages near the garage used as the entrance to pit lane?
^^ Was pushed up beside the scrutineering shed, didn't look good.
Pretty happy with my new PB of 1:56, not bad for a 2 ton car I thought. lol.
My gearbox let me down again, perhaps time for a manual conversion?
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
