Been looking on ebay but some dont look strong.
Im especially just interested in a rear set for now.
Plenty of ones like a horse shoe like this shape (
But seen a few like a double horse shoe shape like this ()
they look alot stronger?.
any links?
https://www.sau.com.au/forums/topic/407347-best-bang-for-buck-r33-camber-kit/
Richo do you know if Cusco are better and stronger then GKtech??
Its pretty hard to tell you if one is stronger thsn the other unless someone does destructive testing on them. Personally i think strength wise there wouldnt be difference its prob it anything quality of the rose joints, cusco ones will probably last longer.
Ask yourself: what do you want them for,
if you're going to drive lots of kays on street maybe stay away from rose/pillow jointed arms - (believe defectable).
if it's for motorsport, ask them how would you source replacement parts - eg new pillow balls.
if it's for bling, get a nice looking set, blue titanium anyone.
As for strength of the various arms, ask yourself, would you put your companys name on something you knew would fall - if they name it, they should stand by it or they'd go bust.
Should have added, I'm looking for a motorsport set myself.
If you want bang for your buck, surely you can’t go past the SAU trader mentioned, me, I’m also considering a certain fabricator from SA, who uses imperial fittings so he can source decent race spec joints cheaply (as the States is imperial).
Its not that they will brake or bend. More how quickly will the flog out and how hard will the be to adjust and align.
Also we are talking front upper arms here the S chassis doesn't need then, as the strut controls that.
For thr rear arm, hardrace with the polly bush for a street / track car. Much better than a rose joint that will flog out in no time on the road to and from the track.
Jon these are the one http://justjap.com/store/product.php?productid=20359
I wouldnt consider anything else.
The cusco does not use rose joints, its polly bushed. I got mine second hand from japan for $300 and 40 track days later and one crashed car. They are still fine.
Rose joints last f**king ages, don't listen to this rubbish. Its not uncommon to buy cheap old cusco pillow ball arms from the import wreckers that have been on a car for years and years in japan, and there is nothing wrong with them. Rubber or poly bushes are shit, it's more likely that the poly will flog out quicker than a pillow ball. That said, cheap chinese pillow balls will indeed flog out much quicker. Thats really the only problem with cheap china shit, that and the fact you have to tell people you have cheap chinese arms.
Edited by OEM_as_f*ck
I don't run a motorsport company, just have my personal experience to go from but maybe you'll want to add Taiwanese to your Chinese pillow ball crap list.
Get clunks from left side of the car, so when I got my alignment done I asked them to give the suspension the once over - result, all connections tight, clunk is coming from pillow ball slop. The suspension has been in for 1yr, 12 driven to track days and <10,000km. Is that f**king ages?
John, just looking at improving my rear setup, front already has coilover struts with camber tops and adjustable castor rods.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
