A big shout out to Scotty NM35 for all his help and skinned knuckles with the removal and install of my turbo!
New shorter core produced quite a few install issues and problems for Scott along the way. But he endured and I have boost again!
Coupled with a 'Scott Dump Pipe' and actuator mod, there is a definite extra kick.
Thanks so much Scott. Love your work.
No problem Dominic, glad to help. Did you get underneath and check it out?
Not very happy with the way this turbo was installed, too many mods required to make it a feasible option. That said the stock like response felt good for an untuned engine.
You are lucky I waived the bandaid tax, costs could have blown right out. :)
Welcome Dominic
Yeah, I hear Scotty does OK work :)
What turbo did you get?
Cheers, Leon.
Lol ok? There were SOOO many problems Scott had to fix after getting the turbo back.
Someone left the door open again, daym wastlanders...
It was the "stock" sized wheels that Stao just designed, only hassle was the chra was 21mm shorter meaning the compressor housing and everything hanging off it was 21mm further back.
I won't be fitting another one of these.
Sounds like the same issue that Craig had when his 3071 highflow went on.
Pick up yo phonnnneee nigggahh
Exactly, even though I was promised it would fit as he had already sold two of them. It's easy to fit when someone else is doing the work though.
Haven't had a chance to climb under and look as yet... Got home from work in the dark yesterday, then back here this morning in the dark! Things one has to do to pay for repairs to a shagged M35 turbo!
Really impressed by the acceleration. As you said, close to stock. Very linear and coming on from approx 2500rpm with the extra kick.
My original post certainly didn't describe just how much stuffing about you had to do. Word of warning for anyone else going down this path... Speak to Scott and he will say, DON'T, I am sure.
Thanks for waiving the bandaid tax - with the number of cuts suffered, the cost would easily been higher than the value of the car!!
That was a mighty big look of relief in the rear view mirror, when I drove off - clearly happy to see my car disappear!
relief?
hahah he was probably pissed off that he had to start mine
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
