A big shout out to Scotty NM35 for all his help and skinned knuckles with the removal and install of my turbo!
New shorter core produced quite a few install issues and problems for Scott along the way. But he endured and I have boost again!
Coupled with a 'Scott Dump Pipe' and actuator mod, there is a definite extra kick.
Thanks so much Scott. Love your work.
No problem Dominic, glad to help. Did you get underneath and check it out?
Not very happy with the way this turbo was installed, too many mods required to make it a feasible option. That said the stock like response felt good for an untuned engine.
You are lucky I waived the bandaid tax, costs could have blown right out. :)
Welcome Dominic
Yeah, I hear Scotty does OK work :)
What turbo did you get?
Cheers, Leon.
Lol ok? There were SOOO many problems Scott had to fix after getting the turbo back.
Someone left the door open again, daym wastlanders...
It was the "stock" sized wheels that Stao just designed, only hassle was the chra was 21mm shorter meaning the compressor housing and everything hanging off it was 21mm further back.
I won't be fitting another one of these.
Sounds like the same issue that Craig had when his 3071 highflow went on.
Pick up yo phonnnneee nigggahh
Exactly, even though I was promised it would fit as he had already sold two of them. It's easy to fit when someone else is doing the work though.
Haven't had a chance to climb under and look as yet... Got home from work in the dark yesterday, then back here this morning in the dark! Things one has to do to pay for repairs to a shagged M35 turbo!
Really impressed by the acceleration. As you said, close to stock. Very linear and coming on from approx 2500rpm with the extra kick.
My original post certainly didn't describe just how much stuffing about you had to do. Word of warning for anyone else going down this path... Speak to Scott and he will say, DON'T, I am sure.
Thanks for waiving the bandaid tax - with the number of cuts suffered, the cost would easily been higher than the value of the car!!
That was a mighty big look of relief in the rear view mirror, when I drove off - clearly happy to see my car disappear!
relief?
hahah he was probably pissed off that he had to start mine
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
