i dont think hgh by itself would be that good, definently need it with other geasr to make it do what you want...
In regards to cycling and lifting, i know a fair few tour de france riders have giant quads which would partly be due to all the bike riding they do.
back on topic..
The worlds comp in Slovakia finished up.
The number at the end of each line is their glossbrenner score (look it up - it's a formula used to take in to account age and weight etc etc.)
Results and points of Oz team at Worlds
WOMEN
Nina 330kg @ 57.3kg - 669.83
Sussy 292.5kg @ 54.9kg - 575.99
Cami 325kg @ 69.3kg - 544.00
Tish 252.5kg @ 52.1kg - 526.88
Amanda 337.5kg @ 76.7kg - 515.03
Vicki 272.5kg @ 57.8kg - 503.69
Bec 377.5kg @ 112.3kg - 497.55kg
MEN
Ricky 847.5kg @ 107.8kg - 754.28
Scott 724.5kg @ 89.9kg - 702.04
Emad 602.5kg @ 74.2kg - 679.62
Max 650kg @ 86.4kg - 665.48
Jack 745kg @ 152.3kg - 629.96
Conor 500kg @ 81.1kg - 562.14
Dan 525kg @81.7kg - 543.90
Zach 565kg @ 144.8 - 500.08 INJURED
Spiros 525kg @ 126.6kg - 492.54 INJURED
57 new Australian records were set by those people above (records can be set for each lift or total so people can actually set up to 4 records in the one comp)
There were a whole bunch of world records set too.
Edited by TTT
Here are the Australian records...
WOMEN
56kg Junior - Tish Wasson sq95/bp45/dl112.5 - total 252.5kg
56kg Open - Sussy Kollen squat 112.5kg. Total 292.5kg
56kg masters 1 - Sussy Kollen sq112.5/bp60/dl120 - total 292.5kg
60kg open - Nina Markopoulos - deadlift 142.5kg, total 330kg
60kg masters 2 - Nina Markopoulos - squat 120kg, deadlift 142.5kg, total 330kg
60kg masters 1 - Vicki Jewson - deadlift 132.5kg
82.5kg open - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
82.5kg sub masters - Amanda Woodward - sq 135/bp67.5/dl/135 - total 337.5kg
90kg+ open Rebecca Zepackik - 157.5kg squat
90kg+ sub masters - Rebecca Zepackik - 157.5kg squat
MEN
75kg open Emad Nayef - total 602.5kg
75kg sub masters - total 602.5kg
82.5kg teen 2 - Conor Zyskowski squat 200kg
90kg junior - Max Markopoulos bench 155kg
90kg open - Scott wasson 265sq/157.5bp/302dl - 724.5kg total
110kg open - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
110kg sub masters - Ricky Goodyear 325sq/202.5bp/320dl - 847.5kg total
140kg masters 2 - Spiros Markopoulos 235sq/150bp/140dl - 525 total
140kg+ open Zach Turner sq 310/bp 190
140kg+ teen 2 - Zach Turner sq 310/bp 190
140kg+ open - Jack Pollard - deadlift 280kg / 745kg total
140kg+ junior - Jack Pollard sq280/bp185/dl280 - 745kg total
Equipped bnench only - 140kg+ Zach Turner 250kg - open and Teen 3
Read more: http://prorawpowerlifting.proboards.com/index.cgi?board=results&action=display&thread=1401&page=6#ixzz27M3Kw8s3WOMEN
MEN
I believe it's something that creates a lot of elastic like tension across your chest...in ways similar to a sling shot? Will let someone who actually knows confirm.
Its a shirt :). Like this one: http://www.inzernet....T_ID=08_TPL_DEN although it depends on single ply, multiply et cetera.
It completely changes the lift, I've tried one on once and could not get 120kg to go down at all, I needed more weight. The tightness is more across the back then the chest when I tested out a bench shirt, but I've never competed in one or learned to use a bench shirt correctly.
There are also squat suits...these also change the squat and allow more weight to be squatted.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
