Birds, the GPC National Push/Pull is on November 18, all around Australia on the same day
You can do both or simply one, so you can bench only, a lot do as its not a combined total, each event is separate
You can also set National records at this event. Being sanctioned, you must join GPC and wear a soft suit
The Vic leg is being held at my gym, PTC Frankston, 2 Skye Rd
Nick, leave a little earlier so you can warm up properly this time
you sound like my old man but you make an excellent point... I will leave earlier
my bro-in-law coming to watch again, been trying to convince him to enter but he's worried about his crappy bench press... I told him it's just the lie down between the real lifts and he had a good laugh... still wussed out though
I don't care if I come last (well maybe a little bit) as long as I beat my lifts from last time I'll be happy
Birds you should enter, last time I did I had done zero actual training for it... I had been doing all three lifts but with nowhere near the frequency or intensity of a proper program... I found it useful to gauge where I stood strength wise
My only reluctance is I'm still recovering from the drop in conditioning that the flu gave me. Right pain in the ass that's been.
Nonetheless, if I have nothing already planned for then and get hold of a soft suit, I'll come along to the Nov 18th comp. Be interesting to see where someone who doesn't have strength goals sits along the scale.
I've been running starting strength for 7 months and I've put on a lot of back size/width, but I do add chins and hanging leg raises once a week maybe twice, you do barbell rows as well (well I do instead of cleans)
Edited by Dani Boi
Birds, you may get a shock and your misconception of powerlifters will diminish
My son Max only deadlifts, rows, shrugs and chins, youll die when you see his back, same goes for Emad, Martin, Jesse, Wayne etc
Most think powerlifters are fat. Maybe the 125kg and up guys are fatter, but the guys under that are quite lean
if your interest is bodybuilding or physique competitions then I wouldn't go balls out to work your 1rms... however running a power lifting program for a few months definitely won't hurt your physique and it could spark some new growth, especially if your old program is a bit stale... its not something to attempt on a calorie deficit though so you need to eat... probably better to tackle during a 'bulking' phase for the physique competitor
Insert pics of Scott, Max, Mike, and Rankin here
I know, it would shock a few hey lol
Triple bodyweight raw squats and deads do tend to take a little bit of muscle to move
One of the comments Max always gets are regarding the size of his traps. They ask him what he does, and he says shrugs. When they repy they also shrug but their traps arent that big, he tells them he uses 220kg lol
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
