I foudn week 9 always got me in trouble when I was doing it.
My training log at home actually has "f**k YOU WEEK 9" on one of the pages
yeah I massively overestimated the squat program... was trying to do the 180kg and got to about week 6 and realised I was in trouble... after just squeaking out that 170 squat I'm going starting the 180 program again... but I'm all screwed up as ProRaw4 is in 3 weeks and I'm just starting the PPP cycles again... I didn't get to finish any of them properly before the last comp either, think the closest I got was bench week 9
I want 180/120/230 = 530... but I'll take 520 and be happy... pretty confident I'll get the bench and dead but the squat will be hard... might have to settle for 170-175
I better buy some shoes/suit... does anyone in Melbourne stock this stuff in store? prefer to buy in person so I can get a good fit
Rest as long as you need
When it comes to strength, fatigue is the enemy, you never want to miss a set because you hadnt rested long enough
You wont get leaner resting less, otherwise those fat f**ks supersetting everything with there PT would look like Frank Zane
Alter your diet to alter the way you look
PPP is not about the weight on the scale its about the weight on the bar
Sometimes at a comp you have to wait 20 minutes between attempts, I train my guys to get used to that sometimes
Anywhere between 3-5 minutes on your heaviest sets
On the assistance we rest about 1 minute, depends on the movement, 20 rep SLDL requires over 5 minutes or death becomes a reality lol
We have some guys do them with 2 x bw
Been looking at the PPP and trying to work out where to start, so from those using it some advice please.
Current stats - 5"7 85kg, bodyfat around 20% and have been training for 11 months.
Current 1RM:
Deadlift - 160kg (that was tough!)
Bench - have never done a 1 rep maximum and normally I stop 1" above my chest (that will change with this program and will ensure the bar touches my chest on all lifts). I think I would be able to do 110kg-120kg
Squat - As above but have done 120kg but not what most would call a 'full deep squat' so reckon I should be able to do 100-110kg that goes deep enough.
So firstly, don't flame for the above, secondly what weights are recommended I start for each lift?
Edited by SRS13
no flame here... no great damage done if you under or overestimate a little... just have to be honest with yourself on form and reps
Markos will probably jump in here but for what its worth...
If you got 160, try the 170 program... if you get halfway through and its still easy jump onto the 175
Get someone to spot your bench press and find out what your true 1rm is... then aim 5-10kg over that for your PPP
I wasted a lot of time when I first started in the gym half squatting... I wasn't training powerlifting then, just lifting to get in shape... I didn't have anyone to judge depth and thought I was deep lol... when I went properly deep I could handle a LOT less weight so get someone to have a look at your squat or video it... its really annoying to get a certain weight and then realise your too high so you may as well go lighter and do everything with as much depth as possible... you'll be a lot stronger for it in the long run
read Markos article on squatting if you haven't already http://www.ironedge....-author/markos/
SRS13
there is a PTC in sydney.
I suggest you go there and talk to TRENT (The owner) and tell him you have bought PPP program from markos and want to make sure you are doing the movements right.
He can walk you through squats and bench and deadlift and you can try 1rms there in his gym using good equipment and spotters.
Then look to increase your lifts by 10kg.
run through the 11 weeks.
at the end do your new 1rms and so on.
Edit - I gotta refresh the page before I start typing
Edited by TTT
Thanks guys :thumbsup:
Will definitely try and do a 1RM for squat going as low as I can physically go. I'll try the 170 for deadlift. Cant do the bench now as physio has said no benching/chest exercises for a while and I haven't done any for almost 4 weeks now.
Didn't realise there was a PTC here in Sydney - I have to check it out!
For the record
http://www.ptcfrankston.com/index.htm
http://ptcbrisbane.com/
http://ptcsydney.com.au/
http://www.ptcperth.com.au/
PTC Gold Coast opening in early November
PTC Doncaster in 2013
PTC Adelaide in 2013
Edited by markos
Henry is a friend and a class act, great gym too with some very strong boys, hoping a few of them come across for Nats next year
Referred a friend to Henry a few months back, he's blown away by the benefits after he had been training traditional gym style for years. Usual things realised, like how his form was poor on the 3 lifts even though he invested in lots of PT instruction etc..
I just need to convince myself to get myself over there now. Suffering from the standard lack of motivation ( read bull-dust excuses). I know once I start training again the motivation takes care of itself. I'd love to be smashing the PB's of ten years ago at my present age of 40.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
