well i went to PTC Sydney yesterday and had an evaluation with Trent. I must say, top bloke, very knowledgeable, not judgmental and explains everything to you in detail.
He sorted a couple of issues that my younger brother was having out in about 30 seconds (particularly squatting) and in the session, young 17 year old 90kg Jack went from struggling to squat 70kg below the parallel to squatting 100kg almost ATG. My squat however went backwards, I got lower almost to ATG but only managed 70kg in the squat rack before form started to drop.
Also tweaked our bench to more of a strong man bench. I can speak now from experience a PVC pipe under your back whilst trying to bench sucks balls (I have the bruises to prove that), seems to have helped Jacks bench technique as well.
Finally we did some Deads, probably my new favorite exercise. Got to 100kg x 3 reps before form started to break. This was after he changed the entire way that I dead.
Trent has also recommended that we add in some leg press and lower back raises to help us with these main lifts and thinks we should go back in about 6 months for another quick session. If the gym wasn't so far away and I wasnt as busy as I am with work, uni, other sporting commitments and the girlfriend I would sign up in an instant. Really enjoyed the entire environment that I witnessed at the gym with all the guys there.
If TL:DR here is the summary, good session, good gym ended up lifting more and less. Would recommend anyone to have a session if they are unsure and will go back.
Thanks guys, its great when the hard work pays off.
Very interesting. I should book a visit when my shoulder is better.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
