Hey guys my beloved r33 got stolen right from my drive way :/
so this vehicle is stolen and recovered (classified as repairable write-off)
the reg is still active at this stage in case some one wants to fix and drive it.
The ignition barrel and drivers window are broken and engine seems to have a blown head gasket.
turbo is missing the turbine wheel i think its in the cat ... lol
there is minor damage just behind the drivers door but looks like a easy fix
The vehicle is still a whole and stock so let me know what parts your after and ill price it up
wheels are not for sale and exhaust.
located in northern suburbs
Thankyou for reading pics up soon
Edited by xm4tr1x
https://www.sau.com.au/forums/topic/407860-vic-wrecking-white-r33-gts-t/
  • Replies 60
Posted Images
Hey mate im interested in buying ur front bar, lights, guard lhs, rear bar and side skirts, i also live in northern suburbs and ready to buy i price is right, please call me or msg me on 0413 556 178, my name is kay, or giv me ur details and i can call u
Rb25det Gearbox drove fine no crunching etc $1000
Front Bar $ 200 pending payment
Rear Bar $100 pending payment
Front LHS quarter $100
Front RHS quarter $100 pending payment
Series 2Headlights $250 pending payment
Front seats $90
Rears $45
Interior plastics From $ 10 just ask
Alternator $90
Ps Pump $90
Aircon compressor $85
Clutch Fan $ 70
Cluster $100
Carpet $ 200
Coil packs $20 each
Engine loom $165
Ecu $100
Suspension arms from $30 just ask
Seat belts $100 front pair
Stock bov with pipe $60 pending payment
Stock Injectors and rail $ 150
Fuel Tank $250
Headlights $250 - pending payment
Taillights $120
Ps rack $100
Dash pad $80
Fuse box loom $150
Rear Subframe $165
Front crossmember $100
Door trims $50 each
Door handles $25each
Window regs $85 each
Power window switch drivers $85 Passanger $45
Window glass $75 each
Door skins $65 each
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
