Hey guys my beloved r33 got stolen right from my drive way :/
so this vehicle is stolen and recovered (classified as repairable write-off)
the reg is still active at this stage in case some one wants to fix and drive it.
The ignition barrel and drivers window are broken and engine seems to have a blown head gasket.
turbo is missing the turbine wheel i think its in the cat ... lol
there is minor damage just behind the drivers door but looks like a easy fix
The vehicle is still a whole and stock so let me know what parts your after and ill price it up
wheels are not for sale and exhaust.
located in northern suburbs
Thankyou for reading pics up soon
Edited by xm4tr1x
https://www.sau.com.au/forums/topic/407860-vic-wrecking-white-r33-gts-t/
  • Replies 60
Posted Images
Hey mate im interested in buying ur front bar, lights, guard lhs, rear bar and side skirts, i also live in northern suburbs and ready to buy i price is right, please call me or msg me on 0413 556 178, my name is kay, or giv me ur details and i can call u
Rb25det Gearbox drove fine no crunching etc $1000
Front Bar $ 200 pending payment
Rear Bar $100 pending payment
Front LHS quarter $100
Front RHS quarter $100 pending payment
Series 2Headlights $250 pending payment
Front seats $90
Rears $45
Interior plastics From $ 10 just ask
Alternator $90
Ps Pump $90
Aircon compressor $85
Clutch Fan $ 70
Cluster $100
Carpet $ 200
Coil packs $20 each
Engine loom $165
Ecu $100
Suspension arms from $30 just ask
Seat belts $100 front pair
Stock bov with pipe $60 pending payment
Stock Injectors and rail $ 150
Fuel Tank $250
Headlights $250 - pending payment
Taillights $120
Ps rack $100
Dash pad $80
Fuse box loom $150
Rear Subframe $165
Front crossmember $100
Door trims $50 each
Door handles $25each
Window regs $85 each
Power window switch drivers $85 Passanger $45
Window glass $75 each
Door skins $65 each
