  • Replies 48
GTRs have holes in the chassis done at the factory, non-GTR don't have these and you pretty much make your car un-insurable when you cut these holes in the chassis yourself.
This. You'd have to get it engineered, which would involve reinforcing around the holes. So even if you got the intercooler for free, it would still be very expensive.
bet plenty of ppl do it anyway tho!
meaning 95% of all gtst owners are driving around uninsured?
Depends if you consider paying the insurance company for cover while not meeting their terms and conditions "insured" or not.
What I meant were the holes in the chassis for the intercooler piping
Yes i know you mean putting holes in the chasis, and more often then not- hacking into the reo
im saying 95% of skyline owners would do this, Yet still pay full comp insurance each year thinking there covered.
Hence my argument in another thread about CF bonnets and other aftermarket upgrades, You would find that most people on here pay full comp, But yet in the event you need to claim the insurance company has every right not to
Edited by sydking
Just do it mate, engineered or not if their out to get you they will get you.
And screw this whole "void insurance" business, I can bet my bottom dollar there isnt a car on this forum with over 260kw that is 100% legal in every sense. Insurance will not refuse to pay you because you because of a certain modification unless it contributed to the accident and even then you have to be at fault for this to occur. Just be sensible about it and you will be ok :thumbsup:
Ok - lets summarise for OP. Sell the GTR cooler and buy a kit that bolts in without having to hack the body. Of course, you can still be defected, but its an ok compromise for most people.
Ever tried to clear a defect with a hole in the chassis though? In this day and age, the shithole parts of Aust that you guys live in, I wouldn't be too eager to make my car any more defectable than it needed to be.
I agree with this and it is an uphill sh*t fight, it helps to know people in the right places that can make things "easier" though :)
always pay to check the regulations where you are, i'm over 260 and fully legal as it sits, i know my insurance will still do the loop hole :devil:
Fully legal? Unless your making that power on a standard computer and standard boost pressure without a boost controller or adjustable tee of some sort then technically no it's not.
I am a big advocate of trying to keep things as legal and standard looking as possible but in this day and age where you can get defected for no water in the washer bottle it's a battle you won't win
hmmm yeah im 15 so i want to use it as a track car but then register so i can drive on my ls as i carnt drive it in victoria on my ps so it will become a full track car at that stage i might just cut it as i have the proper GTR brackets aswell
100% certified as it sits, i'm in NZ though so always need to check the rules where you are
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
