Ev's - R32 Gtr - Targa/sprint/hill Climb Build
Paint is rattle can. 2 PAC paint was roughly costed at up to 4k. Prefer to spend that on something else mechanical.
I thought the paint came up ok. It won't wear well on the floor but I am not too worried as I think I will put stainless check plate on both floors in the future. It can touched up easily enough from time to time as well.
Looking great Evan. Great to see it coming together quickly, you will be out enjoying it in no time. Good plan on going to that extent for the seat mounts. Andrew does a mean floor plate in checker plate alloy - have some in my 34 - nice and light too. Need to get him on to a few things for me as well.
do you know what they used to paint the cage and interior?
VHT do a roll bar & chassis paint in a rattle can that is a little chip resistant. I've used it on various things and it comes up well, cures pretty hard in about a week. Mate used it on his cage and looks same as this.
I know that pain. I have worked in backwards nowhere parts of Indonesia, India, Malaysia..."engineering...taking people to parts of the world nobody else dare"
never a truer word said. I was just up in Malaysia 4, hours out of KL in the banana plantation fabrication yard......
