just purchased a walbro intank good for 500hp, pretty sure its plug and play, just need to hold it in with a cable tie apparently. jeez
Cheap Walbro GS3442 does it for me- just do the direct 12V rewire.
why hard wire it?
Edited by hnr32-25T
why hard wire it?
These bigger pumps pull a lot more amps, not sure what the stock fuse size is but a pump like the walbro 400/416 can pull over 20 amps which is way more than the stock wiring will cope with.
I wired a 416 up the other day (used 6mm to/from relay and 2.5mm in tank) then to test I used a bit of 0.5mm wire about 50mm long to bridge the relay, it fried the wire and went open circuit after 30 seconds.... I have done that same test with bosch 044's and 040's with no issues...
no wires being fried on mine, and no issues so far.
If the circuit is protected by the standard size 15A fuse then its unlikely you will burn anything apart from the fuse itself...
Be interesting to see what voltage the pump is seeing on your setup with stock wiring, i'd say you would be very close to the limit. Might be an idea to carry some spare fuses!
yeah maybe its not stock then, i watched it being wired and put in by the tuner
interesting though, my battery light is on constantly and tuner said voltage is bit high, sitting on 15volts so must need a new reg or alternator, you'd think it would of blew a fuse by now.. have to look into that..
the 400L/hr pump is much quieter than the 255L/hr that it replaced, kind of miss the noise....
Wow that's a pump, over 5l/min at 80psi - that's awesome!! Anyone tried one or got a cost?
Sorry just read the thread - have you tested the return flow to see if it matches the specs?
Edited by rob82
pump arrived today, hopefully fit it on the weekend, someone told me to put a 1 way valve in? but i don't really see the need. anyone else thinks it will help? i might need to pocket a roll of cable tomorrow at work, so wire from the rely in the fuse box down to the pump, do you route the wires the same as factory?
yeah i was thinking gtr pump, but i wanted something brand new and affordable.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
