  • Replies 147
pfft - foot flat to floor in 2nd or 3rd, done
naw
6500 makes nice smoke
also fingers crossed, might have a sony action camera for this one, 120fps @ 720p
I tried that last time and had many dramas :P MOST will be fixed........... BOV is still cable tied epically!
Why dont you get a grabbing point welded onto it? or is that a no go
The idiot that welded it has put a piss weak pipe on it and its collapsing.... So it needs modifcation!
Paid! It's my first time but I dont plan to be gentle ;-)
Good plan! You will love it! Fingers crossed i can make it and watch some skidz :woot:
Steveo... i'll put my form and payment through shortly, but is it ok to carry the balance across to the next one if I can't make this one? I missed the last one due to work, and i'm still trying to get my shift covered for Oct 7.
is that because you havnt lost weight?
its all good mate, im a fatteh too.
You Son of a..................
Nah all good, its motivating :yes:
And nope, its due to the car probably not being ready and i wanna still come and spectate and help out where possible :D
you can run out & reset all the cones that will inevitably get knocked over
THAT will keep you fit, I'm sweating again just thinking about last time lol
Not keen! But will do it due to the amount I knocked over last time :P
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
