Membership forms for the club (also required for my CAMS licence application) where would I aquire one of these mofo's? :)
http://www.skylinesaustralia.com/forums/topic/349895-so-youve-never-done-texi-before/
A bit of the information needs updating actually... Don't take it all as 100% gospel, but the form is in that page :)
  • Replies 147
Wouldn't be surprised if the old super taxi's knock a few out this round but it means more track skidz for those that do come along. Tape the race and come out then go home and watch it - winnar!
Also, the execs have also been working on a new club point score so this event will be the first to get you points in our fun club point score.
More info on this coming out VERY soon.
This will be the first Texi, EVER that I will miss.
I'm happy to say I've never missed one up till this point :)
OMG! OMG!
It's ok Steve. I've got this covered and will be the barking dog getting everyone in ship shape. Aggro you gonna be my back-up, right?
just emailed off entry form and recept.This is my first time and was just checking if anyone from Newcastle was going ?
I was planning to head down and lend a hand... Will let you know later in the week...
Lol car wont be getting a hard time, dont wanna sping a bearing gotta make it to the nats..
ooooh i'm sorry Luke :P hahaha
all good, if you can't have a laugh about it, you need to lighten up.
I think were ok....
Might be important to note: This Is the first day of daylight savings..
You loosean hour!!! what you think will be 7am will in fact feel like 6am. (cause it really should be if clocks didn't change)
Scrutineering/sign on starts 7.00am
Scrutineering/sign on ends 8.30am (don't show up at 8.25am, come with plenty of time to spare)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
