Hi all, I need some more negative camber in the front of the R34 and got some adjustable upper control arms and radius rods:
The control arms are eBay brand (nice eh) and the radius rods are SRI from Just Jap.
I'd like to know the following before I start pulling the front end apart:
1. I think the OEM upper control arm is just one part whereas the replacement is in two parts. The straight bits have this 'diagonal cut' on the side - any idea which one goes on which side of the car?
2. I understand that the radius rods are the ones right next to the front swaybar, correct (see pic below)? It looks like the OEM rod has this massive rubber bush whereas the SRI pillow ball looks very small in comparison. Is this going to cause any issues?
3. Lastly, what's the best way to keep the original alignment? Just measure the original arms and rods & try to adjust the new parts as close as possible?
Thanks guys!
Here's some photos of the stock suspension:
  • Replies 42
You can eyeball it and get it close but you will need an alignment...
The caster rods are correct, you fit them up and they work fine, one again will need adjusting when aligned...
Not sure about the camber arms as I used the bushes!
Nice BC's by the way ;) how u find them?
Thanks! Yeah very happy with them. I ended up going lower-than-normal spring rates (F:6 and R:5, they come in F:8 and R:6 as standard) together with larger sway bars and they work great. Good control yet very compliant ride. Oh yeah and it's a 4 door GTT.
Yeah I kept 8/6 but have the same set ready to go in :) I'll check back in soon and hopefully someone sheds some light on the camber arms, I haven't don't them before so I can't help
With that part... The caster rods are pretty easy :) they are solid so you'll notice a bit of harshness compared to the rubber ones but it's nothing major....
Curved part of arm goes on sides towards front of car. But when you take stock out youll see one side is curvy other is more straight so you essily figure it out.
Thanks boostn. Any idea which way the 'cut outs' on the straight bits go?
Cut out part should be facing on the inside, its cut out to give some clearance for the arm from the wishbone as it can get pretty close.
Edited by boostn0199
  • 7 months later...
Finally got around to installing these, wasn't too bad. Cracking the nuts and measuring the original arms/rods & setting up the new parts to match were the hardest parts. Good long breaker bar is your friend.
One tip for anyone doing this is to keep in mind that the LCA and wishbone drop really far down without the front coilover in place. Therefore only tighten the top front bolt properly after the coilover's back in. Otherwise the original rubber bush will be under a lot of tension when the car is dropped down.
Here's how the arms look installed:
Adjustable front upper camber arms (from this skylineowner.com thread):
Adjustable front radius rods/tension rods (from this skylineowners.com thread):
Adjustable rear camber arms (from this skylineowner.com thread):
Hope this helps.
Edited by V28VX37
Quick question - since installing these (together with 20mm spacers) I am experiencing slight knocking/jarring at full lock e.g. when shuffling around to park.
I have done a quick check of clearances, the tyres don't appear to touch and I can't see any marks anywhere ... Has anyone else had similar, I wonder what it could be?
  • 1 month later...
I ended up zip-tieing the plastic inner guard lining in front of the wheels and it's much better now, no more jarring. There's also a little plastic 'ridge' on the rear side that you just push in for a tiny bit more clearance.
I'm still getting a slight knock/clunk from the front, typically when maneuvering at slow speeds (stop/start). I'm guessing this might be the radius rod ball joint, which has close to no bushing compared to the massive rubber bush in the OEM rod, does this sound right? I knew that aftermarket arms & rods are meant to be noisier, but how noisy is too noisy?
Another question too: The bolts connecting the aftermarket radius rods to the LCAs are maybe 1mm smaller than the holes in the LCAs, so they're not snug. The bolts came with the kit and fit the holes in the radius rods snugly though, so they're the right part. Could this cause some additional NVH?
Did you get a wheel alignment? Presumably you don't want the stock alignment. Too much negative camber will chew out your tyres pretty quickly. More castor is good - anything up to 6 - 7 deg.
The pillowball joints are not ideal for road cars as they will not last as long as the stockers.
Yeah mate full alignment, castor in the 6.5-7 range and neg camber about -1.25 rear/-1.6 front. I'm happy with the settings.
I've heard that ball joints won't last as long but are they meant to be fairly noisy brand new, too?
No. Noisy means they are generally loose! Check to see if the adjustment part is locked up tight?
Ok thanks. I have gone through everything previously (cos it was noisy) and made sure everything was super tight, but will check once more.
Oh well the clunking/knocking in the front is really starting to s__t me now. I have checked everything again and it's all tight.
It's noisy at slow speeds when braking and accelerating, a very clear knock when changing from one to the other. It's not noisy at bumps. All I can think of is that the radius rod pillowball joints are somehow stuffed.
Is there any way to work out whether it's the camber arms OR the radius rods, without starting to pull stuff out??
I think I may have found the culprit ... pulled out one of the rods last night and turns out the front bolt is tapered, a bit thinner at the other end. This means that it wasn't sitting tight through the ball joint.
As a temporary fix I put some electrical tape around the thin end of the bolt and it finally silent. I'll post some photos later.
Has anyone else had this problem with aftermarket radius rods? Where should I look for straight (non-tapered) replacement bolts?
Have you thought about the original bolts?
Yep I'm using original bolts, that's the issue. The original bolts are thinner at the other end (with a respective narrowing inside the bushing of the OEM radius rod), however the hole through the aftermarket joint is straight so the bolt is not snug at the other end. The rear bolts were supplied with the new rods but not the fronts.
I'm using the original bolts with Tein caster rods. So it should all be the same same as what you have. Yes the bolts are slightly tapered just before teh thread, but they are the correct diameter through 90+% of the crush tube of the rose joint, and as such they don't make any noise. I'm very surprised to hear that you can pack yours out with tape, still get them back together and have it silence the noise. Perhaps you should put up a picture of one of the bolts. It may turn out that the ones you have are not original after all.
Ok, here's some photos. You can see that the second part of the crush tube is unsupported by the bolt about 1/3 of its length, and some play is quite clearly evident.
You can also see my electrical tape hack job in the last photo (no issue sliding those in) - unfortunately it seems that it didn't fix the noise issue fully either :(
Next up I'm going to try to find some new bolts, however this may be tough as the OEM bolts are different diameter at each end - I wonder if the bolt holes are different sizes too..?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
