So something that I've recently been questioning is why many results of the 7's in "RB26 turbo upgrade, all dyno results" thread are the way they are.
I'm lead to believe that these are the most responsive turbos of the bunch when comparing against the -9, -5 and -10. Quite certain that most people who
have these turbos are reaching full boost quite a bit earlier than 4,000rpm; if anything, probably closer to the 3,500rpm mark?
Which makes me wonder, why are the below dyno sheets showing full boost at such high rpm? Some are as late as the 5,000rpm mark, wtf?
I understand that dyno graphs and real world may differ, is that what's responsible for my misinterpretation?
Would be great if the owners of the cars below could have a say in this as they would most likely know whether or not the dyno graph is a reflection of the real
world boost curve. Anybody with a similar setup is also most welcome to provide some feedback.
300wKw at 20psi on 98RON
R34 GT-R V-Spec II
* -7 Turbos
* 700cc Denso Inj
* Power FC D-Jetro
* Blitz front pipe
* K & N Panel filter
* Greddy DSBC
* Tomei Poncams 260/10.25
* Tomei Cam Gears
* Bosch 044 fuel pump
* Nismo 3" Exhaust
* Hi Flo Cat
Unopened RB26DETT
Stock cams
HKS Cam gears (inlet at 0 Exhaust retarded 2 degrees)
-7 turbos
TOMEI s/s dump pipes
3.5" do luck exhaust
Trust 100mm fmic
walbro fuel pump
stock fuel reg
Sard 700cc injectors
Power-FC D'jetro
398.3hp at all 4 hubs @ 1.2bar
99 R34 GTR non-vspec
Unopened engine. Done approx 70K.
100K service done with all OEM parts, including water pump, timing belt, bearings and seals.
Adjust Cam gears
Garrett -7s
Stock injector
Stock fuel pump
Stock air box with high flow air filter
Stock intercooler with full HKS hard piping
Nismo fuel regulator
Spitfire Coilpacks
Iridium spark plugs
EVC 5 boost control
Power FC
Stock dumps and manifolds
Full NISMO WELDINA NE-1 Exhaust De-Cat
Koyo Radiator
EXEDY hyper multi twin plate clutch
Tuned @ Racepace
Pulled 288.7 RWKW @ 18.2 psi, on BP 98.
Bought Sard 700cc and Bosch 044, but told no need to install them as I had -7 only. Stock injectors cycle duty @ 98.8%. Knocking rarely exceeds 25 under the sun. Feels hell a lot better to drive.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=322462
Updated in BOLD
1995 R33 GTR
Performance list:
garrett 2860 -7 running 20psi drops to 19psi
tomei dump pipes
trust front pipe
ballistic cat
nismo catback
1000cc injectors
splitfire coilpacks
bosch 044 fuel pump
haltech platinum pro (mafless tune)
bp ultimate 98
115 Greddy front mount intercooler and piping kit
Greddy air intake kit
280awkw at 19psi
Now 310awkw
There are many factors that will influence what your talking about
-health of engine
-how the dyno is set up
- restrictions in exhaust
- aggressiveness of the tune
These are to name just a few
my old gtr had -7's with all the fruit made about 300rwkw and the dyno sheet shows it making full boost at 4800rpm, on the street it definetly feels much sooner then that !
GTR_JOEY:
I agree on all accounts, however the specific graphs I've chosen mainly consist of quite well known workshops which have (I assume - probably shouldn't) relatively honestly setup dyno's. Correction factor will take into account ambient temp and altitude? These setups seemed to have relatively decent exhausts.
SiR_RB:
How much sooner are we talking? 4,000rpm? Below 4,000rpm? Have you ever loaded it up in 4th gear and had a look? I'm quite happy with the idea of 300kw-330kw.
My friend's r34 gtr was already quite quick at 318rwkw tuned by racepace. Mine being 5 speed 4.11FD in an R33 GTR may not feel quite the same, but I'm hoping some weight reduction and mild increase in displacement (86.5mm built motor) would negate the difference of the 6 speed
-health of engine
Exactly. I was driving a mates GTR with -7s not 7 days ago.
I can tell you now by 3300rpm it was well and truly game on where my -5s were ~4000-4200rpm. -9s are about 3400-3500rpm.
Yet when you dyno the cars, the graphs come on & look very similar (nowhere near 800rpm), due to ramp rates and other factors.
Why is it that they have set the ramp rates to make full boost look like its coming on later than it is?
You say that they are well and truly on by around 3300rpm. I take that as the perfect world situation on
a stock motor with all the correct supporting parts.
In the event that you run these turbos with a mild built motor for example with:
86.5mm cp 9.0:1
Light h beams
0.9-1.1mm Thin metal head gasket to keep comp high
Light head work to clean ports and improve entry and exit velocity
A GOOD TUNE
would it be reasonable enough to say that these turbos are likely
to come on even earlier, say around the 3000rpm mark?
-7s coming on by around 3000rpm mark (probably e85 or well sort out
motor) making power to 8000rpm would really be something impressive
I think. Sure it might be short of 350kw atw but a solid powerband of 5000rpm
is not something to be laughed at
-7s will nose over well before 8000 rpm
At the end of the day -7s aren't going to flow much more then 300rwkw and these days that isn't alot of power anyway
Would still be a reasonably quick street car no denying that..
I would find it boring though
86.5mm cp 9.0:1
Light h beams
A GOOD TUNE
When I say "on", you aren't making "full boost" - given such a term is silly. Is "full boost" 5psi or 50?
By 3300rpm the torque is coming on and boost is really driving so at a stab maybe 10psi which is 10psi more than a set of -5s would at the same RPM.
Every setup varies but i think 3000rpm for them to be really moving is a bit of an impossibility.
Despite small increase in displacement, e85 and some headwork?
I understand that stands true for an unopened motor on with 98 but with the above changes?
Edited by RB2600
Fair enough, I was having a look at the build of the old Advan R32 GTR and have just accepted that I won't get it to that type of response.
According to Russ, 3500rpm and the power was already over 300kw with a peak of 380kw-400kw depending on temps. Although it quite an extensive build,
I still wonder..really?
Starting to lean towards the -9 if they're only 100-200rpm behind..
You would need to spend big cash to get that sorta power and response
Ie
Big compression
Stroker
E85
380-400rwkw on -7s is pretty out there
Edited by GTR_JOEY
hi Roy
i will try and tell you what we have found really important and our mods.
power is approx 380 to 400 kw's @all four depending on weather and temp.
so yep, still 2.6 bore size, 270 cams tomei, adj cam gears, cleaned up cylinder head ports, n1 valve springs,cp pistons, tomei rods, n1 oil pump with reinmax gears(also use tomei oil pump previously), hi octane racing large sump (will be going to a hi octane racing 4 stage dry sump in a month or so) standard exhaust and intake manifolds, are intercooler, n1 garret equivelant turbo's, greddy intake boost pipes, apexi airfilters, autronic ecu and cdi ignition,gonzo exhaust, vp109 fuel( good for 30kw's and much safer than pump fuel), tilton brake pedal box, australian spec tein suspension, bosch fuel pumps, advan suge tank, npc clutch ( i swear by it!!), carbon tailshaft. block and crankshaft are standard, acl race bearings, 25 row oil cooler, standard blow off valves. we also run a water sprayer for the radiator and oil cooler for longer circuit runs.
we have tried hard to make the power come on hard down low in the rev range , which makes it easier to drive, we tried aftermarket extractors and the car made more power but we lost over 500 rpm before boost would come on so we went back to standard manifolds, adjust cams to get power as early as possible, car has over 300 kw's at 3500 all the way to rev cut, rev cut we have lowered to 7800 till we get a dry sump.
the other thing we have spent a lot of time on is the 4wd system and wheel alignment setup, nearly all r32 gtr 4wd drive systems we have looked at including our car when we got it, do not function as they should. wheel alignments also have been a real issue. we have had a lot of trouble get alinment shops to align to the spec you ask for and ahen checked they are way out!! we now do all our wheel alignments by string line and have had far better results.
the car will be coming off the road in two months(after nsw dutton and maryborough sprints) for a full rebuild, dry sump if not before) , side exit exhuast for events that allow it, chromoly strut to strut cage, try to lighten it some, total repaint, stack dash , hopefully carbon doors, bigger swaybars & a few other changes.
hope this helps if you want to anything specific just ask
cheers russ
Not a stroker, but a damn good motor lol
HAS he ruled out a stroker??
Not trying to argue with you but he just says "standard bore size" which obviously leaves the door open for a longer stroke size??
It's pretty amazing power if it is all standard but seems to be pretty solid power with fairly standard upgrades and -7's.
I was assuming it was not stroked considering he mentions "standard bore size, standard crank" but now that I look at it, he does mention Tomei rods, so they're possibly the 119.5mm centre to centre model?
Which would effectively increase stroke to 77.7mm?
Bleh...slightly off topic, but I found a lovely crack in the block...guess I won't be thinking about turbos anytime soon...
the crack is actually worse than it looks in this photo :(
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
