well, i finally got around to welding the cracked gaurd, the area is covered in black paint to stop rusting.
now thing is, once my suspension is in, i wanna take my car to work, strip all the paint off, put it in the spray booth......but what colour should i paint it?
im not into bright oranges or yellows for myself, though i dont have any grief with it (hell, nigels supra, and my brother inlaws rodeo, look damn horn!)
i'd like to do red again but probably more darker or something
people, recomend me a colour and a reference to that colour through a picture or something, GIVE ME A HELPING HAND MF!
https://www.sau.com.au/forums/topic/40952-choose-me-a-colour/
yes candy red would look crazy
but go for a silver base IMO
IMO with silver base it will only make the candy red looks like just another metallic red, as metallic base are silverish. The idea with gold base is to add more intensity to the red overcoat because gold has some yellowish metallic spectrum in it.
On the other hand, harlequin will look crazy but depends on what u want, doxx... is that too flashy for you to drive on the street? Or u want ur car to be show car from now on... well garaged, displayed at annual MAS, etc..... :D up to u mate, quite a few ideas here.
yeah a harlequin is way to much for little ol' me :D
thanks for the ideas guys
anymore? :) :)
and shan, yeah we have a spray booth to paint glass splashbacks.....and its coincidently big enough to fit cars in there
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
