  • Replies 47
Hey Mate, interested in the following parts if you still them and happy to post to Gold Coast QLD.
front grill from between headlights $30
headlights $150
Let me know Cheers
headlights $150
Let me know Cheers
both items already sold.
  • 4 weeks later...
cat back exhaust 3.5" - two large mufflers for very quiet operation with good flow (was flowing 390kw) $500
computer Vipec Pugin ecu with optional (external) 4 bar map sensor $1300
RB25 gearbox - rebuilt with all seals, bearings and synchros replaced 30,000km ago (Have receipts) $1700
dif - stock shimmed up to lock $150
coilovers Tien HA $600
adjustable upper suspension arms front and rear $200
brakes inc disks and pads (RDA Slotted, EBC red R + Yellow F ) $400
hicas lockbar $50
intercooler 600x300x100 with piping to suit 3L greddy $120
Stock seats - drivers seat has usual tear $100
nissan floor mats $100
copy gtr wing and bootlid $200
front 1/4 guard L $100
front 1/4 guard R $100
S1 Bonnet $100
S1.5 Front bar $75
Rear bar $50
doors (each) (no speakers or door cards) (pair - 120 each) $200
S1 non airbag steering wheel $50
Gauge cluster (217,000km) all gauges working, white LED lights. $75
dash pad $50
steering rack $100
power steering pump $40
alternator $80
aircon pump + condesner (neither have been used since 2007, probably needs new seals) $50
headlights $150
17x8 + 17x9 Nismo LMGT2 (federal 595 RSR Semis fronts 80-90%, rears on ind) $1100
brake lights $100
light up skyline rear garnish (lights up RED) $150
plain skyline rear garnish $40
Custom Fiberglass sub box (to suit 12" sub) $150
space saver spare $30
brake master cyl $30
clutch master & slave $30
52mm thick alloy radiator with 16" thermo fan $150
Bosch 044 mounted on bracket for intank install including speedflow fittings $150
front Strut brace (Apexi) $100
Starter motor $50
Ignitor $50
stock coil packs - working, spark broke down above 350kw $150
Jim berry full monty - spring centre ceramic button clutch $500
door cards front and rear $100
Castor rods
Handbrake setup
Stereo Brackets
anything not listed or not crossed off is still for sale
  • 1 month later...
  • 1 month later...
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
