  • Replies 70
have you driven a 4puck clutch before? with 400hp the organic might be better for stop/go daily driving
nope never i just turn 19 mate this is my first car ita was project car my friend never got done with so now i own it need to finish the upgrde so the car can run good like it supose 2
An old thread abotu clutches for high horsepower seemed to point to the Nismo twin plate being the go - OR something custom made from NPC.
Are you really making 700hp?
There are significant downsides to choosing a non-sprung centre - they are that driving will suck and your clutch or tyres will wear out very quickly.
for my build the nismo is a bit to much on the island we dont have allot we can do with the car thats why i prefer a npc and so
and i mailed doug responded i schould get a 5 puk sprong 10 inch carbotic button kit
755$
thnxz for the help mates no act or spec clutch for mi
Hey guys... Just wondering what my best option is for a clutch. I am just about to do the manual conversion on my R34 with all R33 bits. The kit is coming with a worn 5 puk extreme clutch so I need a new one before i convert my car. The engine is pretty much stock running 165kw atw but I plan to get a Nistune board installed and tuned for a round 200kw atw in the next few months. So yeah can anyone give me some recommendations? It's kind of a daily driver but i walk to work most days so it's mainly used for fanging around having fun on the weekends.
After doing a bit of research today I think i'm gonna going with an Exedy Button clutch. Anyone know of anything similar but cheaper?
If that's your power goals the jut get one of the NPC organic or cushioned button, better pedal feel than the Excedy one, mine failed so I am biased lol....
And although it's irrelevant to your needs, I drove with my clutch today and it's the best feeling clutch I've ever had or driven :) JB clutches all the way
I've used 2x Exedy clutches before, IMHO the pressure plate is so FARKING heavy, you end up spending money on a larger Nismo slave & Nismo strength pivot ball... get an 10" NPC for the same price.
I'm using a NPC 10" Carbonetic clutch and it's the sht.. a tad more easier to drive than the Exedy Sports Cover (silver plate not that homo modified pink shit)
NPC:
- cheaper
- holds more power (yet to test it on my stock boat)
- bigger clutch (I'm guessing they use a patrol OR 300ZX plate, I'm guessing ok?)
- MUCH lighter pedal feel due to larger disk and plate
Exedy:
- cost more
- holds less power (apparently)
- standard size clutch
- pedal is so heavy, you'll end up buying a larger slave because your left foot is broken (I did that with my old car)
If you must get Exedy, what ever you do, get their Sports range, it's the silver pressure plate, don't get their heavy duty crap.. it's just an OEM pressure plate, modded and sprayed some homo pink colour.
Funny you say that as my Excedy cushion button was like stock pedal feel, but mates NPC cushioned button that looks so close to the same has a heavy (springy) pedal.... My big clutch is lighter than his!
remember Mat, you haz a pull type clutch :)
Yeah but i am directly comparing 34 clutches in the post above.... All in GTT's
Just noticed he is using a 33 box...
Cool thanks guys... A mate ended up giving me a Clutch Industries RPM Heavy duty clutch, so I am gonna run that for now to get things going... In the mean time i'll weigh up my options Gay Pink vs NPC.
watch out on those RPM pressure plates, I removed one from the car I just bought.. clutch plate was in good condition, but slipped like a mofo.. I blame RPM pressure plate
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
