Why billet flywheel?
Are you asking why it's billet or why a billet flywheel is required?
Billet flywheel because of the risk of bursting (not a spelling mistake - burst not bust) the standard cast iron one once you get over certain torque levels. They are like a ticking timebomb. Lots of people run the standard one at power levels over 450whp and nothin happens. Then one day BOOM off comes a leg for some poor chap at the track.
Not to mention the car is also written off because its cut your chassis rail in half.
Not worth the risk for the unknown quantity. I know enough to know that an organic plate isn't going to burst a flywheel and neither is 400hp at the wheels no matter how hard you try. 500hp on the other hand, have seen a few go bang.
Your choice
  • Replies 70
can just imagine a clueless bogan thats managed to strap a to4 turbo on and got over 500hp, a fag in the corner of his mouth and next thing a flywheel comes thru the floor haha.. :woot:
but seriously, that is some scary shit..
Edited by SliverS2
Billet Flywheel is also lighter, and the NPC flywheels have cooling channels that direct some airflow through your clutch. Not sure how effective it is but good idea
kinda wish I'd just gone a twin plate, but I'm happy enough with what I have
I puchased the NPC organic today, it has been stamped on it Exedy UFO52
What would be the difference between the exedy sports tuff clutch rated 280kw and the NPC organic (330kwrated), the material must be the same if it has exedy stamped on it.
Yanks use a "scattershield" or a steel bellhousing to protect drivers at drags. If you buy a Nismo twin plate or similar you get a better flywheel with the package.
Not just for big V8s:
http://jalopnik.com/5502903/video-honda-crx-grenades-entire-nose-in-wild-clutch-explosion
http://jalopnik.com/...lutch-explosion
BUt thats in a Honda and Honda's are for girls dicks.
Had my organic NPC fitted yesterday, is alot better than the exedy,
the gears seems easier to go in too so maybe the old one was dragging or not bled properly, and feels like it pulls harder and very smooth engagement :whistling:
So NPC and my tuner , FTW :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
