Didn't know where to post so thought I'd post up here..
My sisters fiancée purchased a 2011 VE SS and has put extractors on with full exhaust,cold air intake and chipped it with a retune,he has also done some suspension work but nothing crazy..I'm not a hater of v8s and actually like the sound of a niiice cammed one but lately i can't stand his constant shit smack talk bowt my 32 and in his words ' these shitty 2 or 3 ltr rice cookers' thinking they are all this n that when any v8 could destroy em etc etc plus not to mention the teenage hoon mindset he has behind the wheel.He hasn't told me his dyno figure but I'm guessing it would be around the 320 kw give or take. NOW this is my question would my fairly moded 260 kw td06 equipped R32 beat the commo?, I work f.i.f.o in the mines atm so can't take my car to kwinana drags any given Wednesday so am trying to find if they still do Wednesday night drags? And what you guys think the out come would be, 1 good win for Japan or a win to the loud mouth punk in his 6ltr..
Post away your replies I don't get offended :-)
https://www.sau.com.au/forums/topic/410725-na-vs-turbo/
260 in a 1.3 ton car or 300 in a near 2 ton car. but then you have to take in manual vs. auto, 1/8th or 1/4, drivers of each car yada yada and the result is usually too many factors to decide without actually taking them to the strip.
https://www.sau.com.au/forums/topic/410725-na-vs-turbo/#findComment-6562371
No the VE will pump your R32, TD06 or not.
The only solution to this is to fit a L98/77 6L to your R32.
Keep the replies coming :-)
Lol sorry but that's not the only solution bozodos a rb25 or 26 is a more natural progression not take a back step and fit a v8, my brother has the 5.7 ltr VY SS with extractors, full 2.5 inch zorst and some chip and I blow him away every time he gets serious and the 2 times we have been to the plex but seen as tho I know jack bowt the 6ltr I thought someone else would and can give some first hand help or experience with em..looks like the only way this is gonna be settled is on the track
https://www.sau.com.au/forums/topic/410725-na-vs-turbo/#findComment-6564168
The 6l is a different animal to the 5.7 - more comp, WAY better heads and different ECU etc, tend to see better gains out of them once modified; from 240-260rwkw usually (on a Mainline), so yeah around 320fwkw or thereabouts.
Bolt on Gen 4 6Ls often run mid to high 12s on the quarter FYI.
https://www.sau.com.au/forums/topic/410725-na-vs-turbo/#findComment-6564771
Hmmm makes me wanna get down to Perth ASAP and take this to the plex,my car can run 12s flat all day and I have the slips from the plex to back that up as well, i may run a few more psi and see how I go then..also forgot to mention I'm driving a gts4 so grip is no problem and il start working on my launches :-)
https://www.sau.com.au/forums/topic/410725-na-vs-turbo/#findComment-6568367
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
