  • Replies 3.5k
Who woulda thought???  In the '80's Molly Meldrum used to wax on lyrically about him......I thought he was the biggest over-hyped non talented uninspired 'next greatest' ever.  Thought he and Molly must have been in a relationship or something?
But now, after 30+ years, he has finally found some of that much pushed and talked about talent......and its pretty impressive, but his 11 year old daughter is even more so:
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
Been reminiscing with some classics such as Apollo 440, Stanton Warriors, Crystal Method, as well as some modern stuff like KOHH (Japanese rapper) and MySchool (Russian rapper that mostly sings about cars, JDM stuff etc.). Nice soundtracks when working on these cars.
  • 1 month later...
  • 2 months later...
