Wrecking Gunmetal Grey coloured R32 Gtr.
Heaps of parts, first in with the cash wins it.....
Rb26dett long motor $2,100
Speco tacho $60
Gearbox $500 incl shifter. Gearbox crossmember $50
Front mount intercooler (stock) $100
G sensor $150 (not red)
Tailshaft $100
Stock clutch in very good condition $200
Diff $500
Rear cradle (bare) $100
Hubs $100 per hub, front includes uprights
Front lower control arms $80 pair
Front cradle (bare) $100
Front and rear sway bars $80 each
Front steering rack $150
Rear steering rack (incl rack ends) $150
Brake booster $100
Exhaust manifolds $40
Dump pipes $40
Front pipe (stock) $50
Carbon canister $30
A/c compressor $80
washer bottles $20 each
Throttle cable $80
Bonnet release cable $50
Drivers side headlight $100
Bonnet liner/heat shield $30
Rear bar reo $150
Doors $150 each
Tail lights $50 each
Steering column (plastics, ignition barrel and indicator not included) $50
Steering wheel plastics $40
Speedo cluster $50
Triple gauge cluster $20
Door trims $70 each
$10 bin:
-Footrest
-Interior roof light- centre
-Interior front map light
-Kick panels ($10 each)
-Boot plastic trim (bit around the lock striker)
-Door sill plastics (bit with Skyline written on it) ($10 each)
-Maroon passenger door handle
-White drivers door handle
-Various seat parts 10 bux a piece
There are stacks of other parts and trims I haven't yet listed, just ask. I'll be updating and adding new stuff as I get to taking photos and sorting it so check the last few posts for current lists of what's left and what's sold.
Pick up Valley Heights Sydney or happy to post most things, but not all.
Pete
https://www.sau.com.au/forums/topic/410937-wrecking-r32-gtr-stocker-sydney/
  • Replies 148
I'm guessing you have most of the interior bits fatz?
I've got at least 3-4 things that I need but have to way till I'm home to confirm exactly what's broken
Will be home in 3 weeks so hopefully the stuff I need is still available!!
Yea have most of the interior bits
Pete, Do you have the fuel tank cap/sender/cradle?
The 32 one is now on my race car
I have a 33 one you can have for 100
They look the same?
Looking for.....
*Stock ECU
*Steering wheel plastics & Steering column plastics if available
*console surround
*Climate control unit
*center console lid
All if still available or at all?
Pick up
Cheers
Looking for.....
*Stock ECU
*console surround
*center console lid
Pick up
Cheers
Yep got that stuff, the console lid is off a gtst which I think is the same
ill pm you my number
Pete
They look the same?
As long as they are actually the same, I will take it.
PM sent
