  • Replies 73
PM replied.
UPDATE:
Upgraded Turbos - SOLD
O2 Sensors - SOLD
Coolant intake temp sensor - SOLD
Thermostat Snout and Thermostat - SOLD
Open to offers on all items.
Cheers,
Pete
  • 4 weeks later...
UPDATE and PRICE DROP
- Drift Racing/Bucket seat, black, R34 GT-R style, comes with rails to fit all C34 Stagea (as was fitted to my Stagea), R32, R33, R34 Skylines and probably Silvias too. Will not freight, pickup only. Saw these in latest Autobarn ad (no rails) for $150...
$350 $200
- Tein "Type Wagon" adjustable coilovers to suit automatic C34 Stagea (Series I and II), "Low Down Spec Cool Style Master". Fronts have been rebuilt (with genuine Tein seals) and rods re-chromed. Have receipts, not fitted since rebuild (due to sale of car). Rears are still good. Adjustable spring seats, so adjustable in height, damping is fixed valve. Get on these quick!
$750 $650
- Stock Stagea rear upper camber/control arms, left and right side. Also have FR &RR swaybars.
$20 for both offers
- Space Saver spare wheel, T125/90D16.
$15 $10
- High Mount Twin Turbo Kit, gave me 347AWKW. Boxed up ready to freight!
$1600 $1400 ono
- R32/R33 S1 Coilpacks, full set, with mounting frame, 8000km old, P/N: 22433 60U02.
$150 $100
- R32/R33 S1 Coilpacks, full set, P/N: 22433 60U01.
$100 $80
- CAS with mounting bracket.
$100 $80
- R33 N1 dumps, with heat shields, 8000km old.
$100 $80 for both or $60 $50 each
- FR and RR hotside compressor outlet snouts, includes the rear OEM rubber hose.
$50 $40 for both
  • 3 weeks later...
32rrr,
As ^^^ above, the CAS is for R32 and R33 RB26.
Whitenight,
Sorry mate, all hoses (silicone and rubber) have all gone.
SOLD
SOLD
Deposit Taken, will be sold tomorrow.
Cheers,
Pete
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
