Grab a pair of R34 GTR dumps? not 100% on the size but been proven to flow more then you currently have.
If it was me just get some big F off 3 inch dumps!! :D
And "high" flow that cat!
I'm already running r34 dump pipe. I thought the r34 were pretty much the same as the tomei so I never thought 3 inch dump pipe were sold. (beside going custom, I expect)
  • Replies 50
got tuned yesterday. its 3 celcius out there. traction is no good so very hard to tell how ir really drive. so far its good but was hoping for a little better kick in the seat. I managed a 11.8 at 121mph yesterday but like I said, traction was very bad, I was slipping so badly and I don't have any slick, just regular sumitomo tires.
I'm in north america, not australia. What you mean no resolution ?
I ran 11.6 @ 119mph in my old 32 GTR, that was making only 318rwkw(gt-ss) so you most definitely aren't making the power you say you are. My friend also ran 11.2 @ 128mph in his 33 GTR making 412rwkw(-5), that's the mph you should be hitting.
Also what's with so many people saying -5's are making sub 350 with only "lucky" ones getting near 400? My current made 380awkw and as i mentioned before my mate made 412rwkw, both on 98. I would be pretty disgusted if i only made 350rwkw on -5's :/
The 412rwkw spoken of is a bad example, his clutch was slipping on the day. His clutch did not bite in 3rd most the time, but also sometimes in 1st and 2nd. He only got one clean run with a 60ft of 1.87s/11.27s/127mph. His 60ft is slower then yours yet his time and trap speed are the same, so quite possibly 3rd gear slipping again.
Yeah sorry, forgot to mention that.
yup. dynapack reading 2wd.
Your dyno is setup wrong, whats the HP correction mode? sounds like its the old din or STP mode that reads flywheel.... it should say SAE 2004 which is the latest correction method up the top of the dyno sheet like these.
I have the latest dynapack and can tell you there is no hope in hell that car would make that power if the dyno was setup correctly.
Post up a graph so we can see the correction, it will help your tuner get more realistic results.
https://www.facebook...ChequeredTuning
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
