i cant drive wit a wooffer in the back , too much gs lol it would bang every single time i drift or entry a corner too fast :P
other then that , this car his MARVELOUS , love the color sheme wit the brake crazy 6 pot and everythang , good job
crazy ride
  • 4 weeks later...
Here are a few randoms I took when the car was up on stands.
I removed the front bar to get a good look at it and check everything was OK prior to road worthy and registration.
NISMO OIL COOLER DUCTING
NISMO OIL COOLER DUCTING / GREDDY OIL COOLER
This is exactly where I'm putting my oil cooler, I'm going to have to fabricate ducting like this to encaptulate the Oil Cooler.
Having the front and side vents should allow plenty of airflow through there.
Looks awsome mate, any plans on upgrading the front bar to a nismo to make good use of the oil cooler duct, im having a similar delema with mine, dont no wether i should keep the standard bar or get a nismo. It just seems like a waist to have a cooler but no get enough air running through it.
I have thought about what I want to do with the front bar and my thoughts, at this stage, are...
Nismo Z-Tune: Love it but to be honest it has be done so many times now, I think I want to stick with a road less traveled
Nismo S-Tune: This is going to be my preference IF I end up changing the front bar, it will suit my stock guards and bonnet more than the Z-Tune bar
Nismo oil cooler vents: I don't mind this option as it retains the stock bar and just adds a more efficient path for air flow
Leave it stock: This is actually my preferred option. The way I see it is that if the Mines R34 can use a stock front bar with no Nismo oil cooler vents on the front or side of the factory bar then it must be OK. I have to assume that the Nismo oil cooler duct is enough to ensure air is caught and directed through the oil cooler and then just disperses out into the inner guard area.
All though it does look like they have removed the inner guard, so maybe that is why.
Remember I have actually removed the REAR half of the Nismo ducting you can see in the photos of mine above, so once the air is forced through the cooler by the front duct it should just disperse.
Fantastic car.
I also like the Nismo oil cooler vent as it's subtle and you don't see them that often.
Having said that my car has the nismo front bar and the nismo oil cooler; the previous owner also drilled holes in the plastic guard to let even more heat out. Have a spare oem plastic guard intact if it needs to be returned to stock. Seems to keep the oil temps down nicely.
I also like the nismo vent which seems to have purpose but retain a subtle look on the front bar.
Although you are right, the Mines car does fine without one as these pics show
You can see the mesh behind the oil cooler (got photos from one of my many GTR magazines)
The mines car appears to run two oil coolers (I'm assuming one for the front diff???)
Thought this was interesting.....the mines car uses this type of sump extension
Sorry to mix up your build thread a bit, just wanted to help.
BTW you have a beautiful car :thumbsup:
Thanks Ant,
That is really good data, thank you.
I like the way they have just cut a neat rectangle out of the inner guard and covered with mesh.
I think I will do the same.
I have already removed the rear half of my Nismo ducting (behind the cooler) so this will just help draw the air through the cooler and suck it out into the front wheel cavity.
I actually took the car for its firast really hard run last night.
I did over 150km of hills with a variety of 3rd and 4th gear corners, then into some 4th of 5th gear straights and then onto some really tight 2nd and 3rd gear corners.
After 150km of virtually non stop hard running (only had 2 quick 5 minutes breaks) it did not break a sweat.
The hottest oil temps I saw were around 87 degrees and the hottest water temp I saw was around 79 degrees.
I am sure this will be different on the track though.
  • 4 months later...
Hey Shaun, great looking car!
I've got a Greddy oil cooler, but no ducting. I might have to get the nismo ducting coz it looks so purposeful!
I'm not sure the one on nengun for $300 would be in carbon like yours though.
It will work well with my R-Tune (or is it S) front bar
Cheers.
The Nismo duct is actually made from FRP.
Yes, very effective as it is so contoured to fit both entry and exit side.
Just noticed this for sale on carsales? Glws
Nah, I work at Carsales and was just playing around with our system and using my car as a test. I have taken it offline now.
Would maybe consider it if the price was right, but no, not for sale :-)
  • 1 month later...
Not much activity from me lately.
But I have been scouring the Import Monster website looking for bits and pieces from Japan.
I have decided I want to put all of my induction back to standard as I am really chasing...
1) A standard appearance under the bonnet
2) Get rid of the induction noise
3) Get rid of the external vent BOV noise
4) Get rid of the turbo shuffle
It is going to be really interesting to see how it drives and how it sounds once all this gear is on.
I managed to find everything, even the factory BOV recirculation pipe that goes under the intercooler back across to the intake.
I will keep you all posted.
kyokonda11-thumb-137392306973258_zps8cd7
powergroup_shinethu-thumb-13765751782907
powergroup_shinethu-thumb-13680217188906
hrc16005760-img600x450-1376835506jmcgpu4
n1civicek4-img600x450-1374097594c0wuvv83
ttn58pt-img600x450-13544288193clmgx71594
n1civicek4-img600x450-1374097593clhbw383
  • 3 weeks later...
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
