Just wanted to know what the fine for running a decat pipe is, and whether anyone's been done for it? I hear the fine is something ridiculous like $10,000 and mobile EPA officers at defect stations can d!ck you for this simply by getting an emissions reading and extrapolating the fact your car is passing out very dirty gases.....can someone shed some light on this?
https://www.sau.com.au/forums/topic/411852-fine-for-decat-pipe/
EPA victoria will apply to you: http://epanote2.epa..../$FILE/1031.pdf
Bare minimum fine looks like $1000 (1 penalty unit). If you knew how many penalty units having a decat would give, add 3 zero's on the end.
If I had to guess, you would get 1 penalty unit for every exhaust gas (nitrogen, water vapour, carbon dioxide, carbon monoxide, hydrocarbons, particulate matter, sulfur dioxide, nitrogen oxide, ozone?, lead?) which a cat converter would otherwise have dealt with on some scale.
So it's easy to see where the $10,000 fine can come from.
I would never run a decat Terry, I was just wondering because I was having this conversation with a mate and he told me the fine was in the vicinity of 10k which I found hard to believe :I
Holy @#$*, I don't know why people have them and run the risk of copping a 22k fine :/
I have never heard of anyone getting that sort of fine, Its not somethign that you can test really test for on the raod, Nor can your avg joe cop.
though if you rocked up to EPA with a decat you deserve the full ammount, Keep a stock cat on hand.
its not like your 100 cell cat will pass emmisions anyway.
^ this
all rumours, who do you know personally that has been fined? no one.
In NSW a penalty unit is $110, not $1000.
CRIMES (SENTENCING PROCEDURE) ACT 1999 - SECT 17
Penalty units
17 Penalty units
Unless the contrary intention appears, a reference in any Act or statutory rule to a number of penalty units (whether fractional or whole) is taken to be a reference to an amount of money equal to the amount obtained by multiplying $110 by that number of penalty units.
