As stated, if the motor is out of the car, you'd be mad not to give the engine the once over.
That said, cluster guage oil pressure is horribly inaccurate and at times does not even work at all for me. If the motor was/is running I'd be checking the oil pressure with a 3rd party oil pressure guage to get a tangible result/baseline.
  • Replies 80
The block is still in the car, block will be coming out and it will be getting checked over and if it is a n1 pump I will be putting on a drive collar that's if nothing is too stuffed in the motor already
Sure... its definately advisable to have the crank collar fitted. However, depending on the intended use of the car, I do not think it is essential.
There are plenty of cars out there getting around with the smaller oil pump drive area with no problems come 150 XXX kms...
I for one would not be pulling the motor down just to install the collar...
Edited by R32Abuser
Ironically although I now sell crank collars I don't have one in my RB30 and I do have an N1 pump (10,000km so far). I am not planning to pull the motor out until I can afford a rebore with forged pistons full balance etc and then I will do the crank collar and assuming the pump is still in one piece (I don't limiter bash) I will put some aftermarket gears in it.
Yeah sweet as man seems heaps that are putting the n1 pump on do put the drive collar on, but I'm still not 100% sure if its a n1 pump or just a standard replacement pump, either way there is no drive collar on the crank so just gotta wait to pull the oil pump off and inspect on what went wrong hopefully everything is ok,
The car was been build for 400hp old owner never got a tune done and was running 11psi and use to give it a hard time, he even had it running 21psi he says...
Yeah engine builder told him from the start get a tune but he didn't.... But only 200ks on fresh rebuild with new parts and it already screwed out the oil pump? Could this happen only on 2000ks from rebuild, I can't wait to see what I find in there
Has the oil restrictors in the block been changed i have a forges engine with nitto pump and had to replace 2 of the oil retrictors for smaller size
as the larger pump sends excessive oil to the head leaving the bottom end in short supply not a good thing to do on the limiter i think you may have more problems than just the oil pump.....
Do it once and do it right, pull the thing down and see what failed.
Next step is crucial DETERMINE THE CAUSE OF FAILURE.
I can not stress how important this is, I see so many engines being built then die shortly after from the same thing due to no one fixing the original problem that caused the first failure.
Then get someone who knows RB engine to fix the problem and build you a strong engine.
Then happy days.
This would have initiated an automated SMS to Ash,
Let the battle begin :whistling:
:laugh:
More than enough info around about N1 pumps for people to decide themselves. It generally is not the actual pumps fault.
Driver/treatment, collar installation/overall balancing & tuning - all have a bearing on if they will last or not.
Found out some more info from old owner, when he was doing a burnout on limiter it just started to bog down and got hot,
He has also status that on idle the revs would drop down to where she would almost stall and that use to make the oil light flicker on fately... Believe the gauge was still working... Anyways it's at the cop and they are gonna start pulling it apart in 2weeks time to find the real problem
Sorry guys, havnt pulled the pump off just spoke to the engine builder and he told me that it's a n1 pump and he didn't put a drive collar on as the one of the crank was fine and when it trail it on it was gripping enough on the gear and crank,
When we finally get the pump off ill let yous know, he is just busy
So pulled the pump off, it has like a mark taken out of it on both sides with it has a high spot hard to explain,
Pulled sump of.... Metal everywhere, 5 oil squiters on the block have snap off, bearings are f**ked, #6 and 4 got really hot, crack is scored
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
