I know the feeling, used to happen to me.
I got two jobs, work 7 days a week,go to gym 3 times a week and I study at home. Planning and time management is the key.
Drink plenty of water, seems to help me with the stress. And always keep reminding yourself that it will all be worth it at the end.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6829872
  • 1 month later...
I love to sleep. Actually doctors advised that every person should sleep 7 to 8 hours daily at night. And child should sleep 11 to 12 hours daily at night. That was the most important to stay healthy and also good to keep your body fit. And if you want to gain weight then you should also sleep well and also eat well.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6874575
I'm a terrible sleeper. Should go to the doctor but it seems I'm happy enough to take medical advice from anonymous users on a car forum. Downloaded the app and will see how I go.
We seldom offer bad advice.
Now sign over your car collection to me; this will save you hours of headaches and servicing costs.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6875318
Birds I will gift you my Mazda6. I'm sure that's what you meant. New tyres, brakes and wheelbearings - cracking car. Sleep app worked well but at this stage is proving to be more of interest than help. It shows 5 points of deep sleep and 1 point of awake over 8 hours. Deepest sleep at 4.00 and a wake up time of 5.12. Alarm was spooky as it goes off just as you are waking anyhow....Seems like a coincidence until you remember how it works.
The acceleromiter dooby in the iPhone is very sensitive and I was impressed how well it worked on its test.
Can't get a screen dump or an image file off the phone so can't share. Will take technical assistance.
Above performance assisted by an over the counter sleeping pill.
Edit, found a way to get the image. Not sure about file format. See how we go.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6875623
what is the go with these sleep apps?
what are they meant to do? help you achieve? offer what adivce? are they bs like testosterone pills? how are they meant to work?
They just learn your usual sleeping pattern, then time the alarm appropriately to wake you outside of REM sleep.
That and you can use them to see your own sleeping pattern for insight.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6876008
they work via the accelerometer in the phone. so it need to be able to feel you tossing and turning. they are useful because it will wake you at 6.47am when you are at a lighter stage of sleep vs 7am when you may be going back into a deeper sleep. basically its less of a shock to the system and you dont feel as groggy when you wake
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6876422
For the record Leesh, you don't need to have it right next to your head. There should be a "test" mode on the thing where you can trial different spots on your mattress. Just chuck it into test mode, put it on the other side of your bed from where you have your head, and move around a bit. It should make sounds to indicate it's picking up your movement.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6878567
Not a matter of worthy dear. This is sometimes due to burden of work that you have done for last few days or weeks. Or may be due to the style of sleeping that you have adopted. Sometimes you feel comfortable in new one but not your body organs. So, try to relax and calm down.
https://www.sau.com.au/forums/topic/412794-sleeping/page/5/#findComment-6890904
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
