got a few parts left over kicking about, as follows below
pics on request
r32 aircon compressor n mount $80
r32 a/c condensor and most lines $100
r32 gtst metal fuel tank $100
r32 gtr/gts4 atessa....sp? reservoir and lines $40
r33 hicas unit $50
r32 gtr rear sway bar $100
rb20/25 push type excedy heavy duty button clutch $500
near new 500-1000kms
3" split dump/front all in one with $50 worth of heat wrap $150
located VIC -SE
pm or post
Edited by Dan_J
good condition i presume, was removed from a wreck, not due to being faulty
also added
gtr/gts4 manual gearbox cross member and mount $80
rb20 auto tranny Free
might be the 5psd as it came out of a cefiro
s13 sr20 auto tranny free
bump
clutch kit set me back $670 few months back
pics on request
also got
rear s13/r32 JIC coilovers -$150
height adjustable not damper with helper springs, one is leaking
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
10 AN turbo oil drain fitting from kando - $40 ------ $50 posted Aus wide
, awhile back bought the wrong one so got this laying around.
suit high mounted turbo or similar with stock oil drain bolt / hypergear.
from the thread start to end its 36cm, 32cm not including the thread on the nut thats crimped onto the braided line
you need to get an adapter to bolt onto the block to 10an
look like this but longer and no barb ( do have one to suit if needed tho)
$%28KGrHqZ,!qgE-y+Ppm%29yBPy+-ElHYw~~60_
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
