Import Monster Sauvic Deca Motorkhana - 8Th December 2012 - Entries Open
  • Replies 195
Posted Images
I'll be leaving from S.E. Suburbs at about 12:00pm on Friday, can meet people either in Vermont at that time, or Wallan BP at approx 1 -> 1:15pm
Anyone have a spare seat to deca? around croydon area?
If so, im coming to volunteer.
On the road handjobs/other negotiable.
Edited by longboy
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
