  • Replies 145
Posted Images
Hey does anyone know, i'm in the middle of complying a 4 door R32 GTS-T. Are the rules for side intrusion bars the same? Do you have to get bars just for the front doors, all doors or don't have to get any at all? Dunno maybe due to the pillar between the front and rear doors means that you don't need them? I'm guessing it's the same for all 4 door vehicles so has anyone who recently complied a 4 door vehicle needed to install intrusion bars?
  • 3 weeks later...
im in SA and complying a four door r32. all doors need bars, high mount brake light, fuel filler and unleaded tag, replace tread, baby seat points, return to stock struts, silencer for exhaust, replace pod for air box, return to stock steering wheel and most anoying is taking off the heavy tinting on the back 3 windows. i have a fun weekend ahead of me *nods*
I'm surprised your engineer wants the stock struts!?!?! he should be able to certify what you have got (I've got ZEAL coil overs in mine and they were fine!!!)
He also certified the pods! talk to your engineer....
Can i just say you guys are getting ripped off in the eastern states!!!
it cost us 150 bucks for an engineering certificate in SA...
so realistically you can get it all done for like 600 bucks!!! There are guys who offer it for that price over here!
all the best
Sure the certificate may cost $150 bux.. it's about that here... but in SA do you need to install intrusion bars in each door? install a fuel restrictor cap, change all seatbelts, and the other minor things? Each of these items is several hundred dollars each.
all the best
mate, you have it easy with the engineers cert! best I could get over here either Sydney or ACT was $450!!! would have cost me bugger all if I got it for $150...
Side intrusion bars are overrated...lots of compliance places just weld in square metal tubing and get them ticked off. things like fuel filler neck,..that is where you are getting ripped off also. Those things are like 30 bucks and then all they do is knock them into place..shouldnt cost two hundred bucks! and some schmuck payed 200 dollars to get his mirrors done.!!! what the?> take them down to a glass place and get them made up for like 20-30 bucks and glue them into place!
anyways im no expert but you guys are getting done i think
I agree with Luke - anyone paying $200 for mirrors and fuel filler reducer are being robbed!!! I didn't haev to do my mirrors, and the engineer gave me a sticker for the fuel door! no restrictor needed!
restrictor is needed in some states.. rather than just a sticker. Trust me, I tried. Like guys you can go on and on about "how everybody is getting ripped off" but some requirements are MANDATORY that are not in some states.. and of course how thorough your engineer in accepting things is another matter.
but there are different requirements for different states which require different costs (but no not $200 for mirrors).
JAS .. seat belts are very expensive yup for what they are. If you are lucky you can get some of a wrecked R32. I got mine for $100
Every State has different requirements. Perhaps a list of these requirements can be tabulated for each state and put in a new thread and made a sticky? It will save on confusion and the same questions be asked over and over.
blacky (or any West Aussie in the know)
If anyone knows about the updated 15year requirements (since april 4 2004);
Is a engineers cert. required in WA? I have been told that it is required, but you can take it over the pits and they will do the eqivilant of an engineers check/report if you don't have one for an extra charge.. (maybe this is only for stock-ish cars)?
  • 3 weeks later...
Thread's gone a bit dead, but i was wondering if a particular engineer was needed to sign off the compliance, or if a normal engineer (mod plater in qld) could do it?
Hi Neil
Anyone that is an automotove engineer will be able to certify your car and the mods. when you contact someone about it, just tell them what you require and the level of mods that you have.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
