I also spoke to Raj about compliance for my BNR32. Very helpful. He faxed me the entire v10 ADR compliance document so I could perform the easy stuff myself and leave the rest to him. :)
Going thru it, i've come across the following:
adr 7/00 hydraulic brake hoses - requests for SAE/FMVSS/DOT compliance. My car came with braided stainless steel lines. Will these need to be replaced?? hope not. :P
cheers
  • 1 month later...
  • Replies 145
Posted Images
  • 3 months later...
Hi, I just bought an uncomplied cefiro off a mate and Im getting it ready for compliancing in south Australia.
It has:
Side Intrusion Bars (do I need an engineers report?)
Child restraints
Fuel filler neck and sticker.
I need a tyre placard? (anyone got one for a cefiro?)
I need seatbelts (what seatbelts should I use for a cefiro?)
will coil overs pass regency or should I try and find some standard struts?
anything else Ill need?
in sydney you pay 1200(100 more if you want the blue slip) for a shop to do the same thing(about the same price you payed for all the things but you did them)
advantage i think you would get is you might use better grade oils
the main advantage to me would be that the car is with and u know exactly whats been done
  • 1 month later...
Does anyone know what year Side intrusion bars came standard in all cars by law??
Curious if a 1991 gtr would already have them? I thought they came in in a standard in 1990 or somthing
Also the best way to find and engineer to do the sign off is to just call dotars yeah?
Tryin to find workshops that would do S I bars in rockhampton is gona be HELL or impossible
Edited by andy25
Ahh thanks for that lads ^_^.. I knew it was somthing like that.. Another Q tho why would anyone bother welding them in when they can be riveted does it look just as strong? im almost sure all this has been brought up before so sorry
Depends on the engineer that signs em off. One of the ones we use prefers to have them welded in on both sides, and won't sign off on the car otherwise. Another gets em down from QLD, bolts/rivets em in and signs it off, although he won't sign off on it unless it was installed by him.
  • 8 months later...
hi
I complied my gtr last year in nsw
used a u shape bolt in bracket at the front so the door was not removed and L shaped bracket at the back with countersunk 5mm stainless screws that are hidden under the door rubber.
have to remove the storm mold and the window and window regulator
no welding on the car 2x 8mm holes drilled behind the front of the door trim and 2x 5mm holes drilled under the door rubber at the rear.
the bars are 25x50 rhs
the full length bar can be manouvered in through the top slot of the door after the window has been removed because the end brackets bolt on
it took me a week to do both sides including lots of time measuring and checking for glass clearance.
  • 1 year later...
hey fellas
im getting another skyline soon a 32gtr i hope depending on total cost involed
D.I.Y compliance is this still possible today,have laws an regs change so it can not be done any more???
if it can still be done where would i find the list of things that have to be changed????
also when they have all been done then what, do i still have to take it to a complier to get documentation?then is this when i got to rta to get rego?
thanks
Hi,
sorry, no more DIY compliance.
We do R32's (June '92 onward) for $2500 inc GST.
Located in Melbourne, VIC
best,
david
hey fellas
:P
thanks
  • 2 years later...
no, what you need is compliance and the CIN that you get from the complier. apart from that you need to check state requirements. in NSW it's a blue slip inspection. and 'engineering certificate' is a pretty general term and covers a lot of things. they are usually done to certify non-standard vehicle modifications though.
i live in qld and i just recently bought an 89 nissan infinity q45 uncomplied. it has been in australia since december 2004. im wanting to do an engine conversion in it and do away with the vh45 as its seized up. i wont be putting another vh45 in. i know the engine needs to be running for compliance. however does it need to be the standard one? also im looking at upgrading brakes/ suspension and putting in a rollcage. am i able to do all the modifications including the engine conversion then just see an engineer once? also can someone point me in the direction of everything thats needed to be done in qld for compliance purposes. thanks Dale
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
